RV.Net Open Roads Forum: Truck Campers: CR1110 Refrigerator install in my TC
 > CR1110 Refrigerator install in my TC
c.traveler2
Moreno Valley,Ca.
Posted: 12/30/13 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you have to watch a video.
12Vdc compressor refrigerator have been talked about in this forum off and on. When my Norcold 300.3, an absorption unit, died again and for the last time, I decided to go a different route. Looking into the 12Vdc compressor refrigerator and asking many questions and doing several weeks of research, I decided upon Domentic CR1110 as the best fit for my needs. Watch the video for the rest of the story, I've had two link to that can be used.
click on pic for video
Youtube link: CR1110 Install
I have one group 27 house battery and 85 watts of solar and have had no problem in maintaining proper battery charge.
Thanks for watching my video, post any question you have about my project.
2007 F-250 4x4 /6.0 PSD/ext cab/Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
cewillis
Tucson, az, usa
Posted: 12/30/13 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
It would have been done a lot faster if you had taken Dave's first suggestion.
Cal
c.traveler2
Moreno Valley,Ca.
Posted: 12/30/13 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I felt like doing that at times with the old unit.
~DJ~
Boise, Idaho
Posted: 12/31/13 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Good Job!!! I see you were doing your Spiderman impression again!! Good thing you didn't fall off this time!! LOL
Mine goes in to the shop next Monday!!! They are charging me 2 hours for the R&R. With my back the way it is right now and I don't have a helper I figured it is money well spent.
Then I am going to look into a solar package.
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
c.traveler2
Moreno Valley,Ca.
Posted: 12/31/13 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
At least the TC wasn't moving, adding solar is a great way to go. I did add solar several years ago and been great.
sabconsulting
High Wycombe, UK
Posted: 01/01/14 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Great video - I hadn't thought about using video to record camper modifications, but it does give you a good impression of what is really involved in the job that maybe pictures on their own don't.
One warning about these CR-series fridges (not a problem you have experienced), but anyone installing one needs to make sure they have good thick wire from the battery to the fridge - that one caught me out - I had a really long run of wire that was OK for running the absorption fridge, but on plugging it in the transient current draw as the big capacitor in the control unit charged, dropped the input voltage enough for its battery protection circuitry to shut itself down with no indication of what the problem was - just looks like a dead controller unit.
Hence for anyone else doing this swap, if the fridge seems dead on 12v then try it with a jump start cable or similar heavy duty cable to the battery to prove it is working - if that is OK then it is just that you need thicker wire or a shorter run of wire to prevent the voltage drop.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'98 Jeep TJ 4.0
'15 Ford Fiesta ST
'09 Fiat Panda 1.2
c.traveler2
Moreno Valley,Ca.
Posted: 01/02/14 02:40am Link  |  Quote  |  Print  |  Notify Moderator
Steve.
Thanks for the input about the 12Vdc wiring that's one of the first thing I'd checked out, as it turned out my original 12Vdc wiring was more than enough and I did remember your posting about that problem you had regarding the wiring.
Mello Mike
Mesa, AZ
Posted: 01/02/14 03:19am Link  |  Quote  |  Print  |  Notify Moderator
Good job, Alex. Looks like a great little unit.
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
FreeLanceing
Grand Haven Mi
Posted: 01/02/14 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Nice job, and nice video. We share the same camper, same year as well I believe. I have had my trials with the N300.3. I was wondering how you got the old unit out. As I recall it does not fit through the door. Sawzall it in half, remove the door? I was also wondering what that new unit cost. What if you don't have solar but maybe 2 batteries. I normally have 110 availible and could always run the honda for recharge. I imagine it would work great going down the road with the truck charging the battery. Mine still works but its not dependable. When I camp its rarely above 80 so I limp along.
Mello Mike
Mesa, AZ
Posted: 01/02/14 06:58am Link  |  Quote  |  Print  |  Notify Moderator
In the video it shows the door separated when its placed on the bed.
