Lantley
Ellicott City, Maryland
Front mount bikes racks are an option. However they present clearance issues,may block headlights and vision,extend the front end and reduce air flow to the engine. Pin box racks do not create any of the above issues.
I had a front end rack for awhile, but then I discovered the superiority of tongue mounted/pin box bike racks and have not looked back.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
WE CAMP2
Petrolia, On. Canada
Lantley wrote: Scott 85 you also have a short bed which may create clearance issues
I have a short box F350 and I often carry 2 kayaks on the roof of the truck with the ends sticking about 1 foot over the back of the roof and 2 bikes on our pin box mounted bike rack and still have no issues.
2017 F250 CC SB PSD & 2008 Cameo 5'er
lpxguy
Chalfont PA
Scott_85 wrote: I like that idea but I don't want to remove my hitch cover do install it.
I still have my cover....I made mine though
![[image]](http://i51.photobucket.com/albums/f398/GMtech45/IMG_05491_zpsfdec0e7a.jpg)
2005 GMC Sierra 3500 CC DRW D/A(FOR SALE)
2013 Crusader 335BHS TE(FOR SALE)
Scott_85
Virginia
![[image]](http://i1363.photobucket.com/albums/r705/scott_85/camperfront_zps79f32279.jpg)
This is the problem.
TV: 2013 Ram 2500 Laramie, G56, Andersen Ultimate 5th Wheel Hitch.
5er: 2013 Coachmen Chaparral 280RLS
nremtp143
Georgia
I made mine for under $40. Several of us have. Do a search and you will see many of them. As far as the shroud, it can be removed very easily.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
sunnybrooktoyhauler
new jersey
I built one very similer to lpxguy. Would not have it any other way. I use a swagman bike rack. It only takes about an hour of your time. Have 2 friends that want me to make them one. Just waiting for the snow/ ice to go away
ependydad
Here and there
lpxguy wrote: Scott_85 wrote: I like that idea but I don't want to remove my hitch cover do install it.
lpxguy -
I actually was looking at another of your pictures of the actual un-finished product. This looks to be a receiver tube, a piece of angle steel on either side and a cap for the front. Can you tell me how long each side of the angle steel it is? Looks to be ballpark 2"-3"?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Puddles
Lafayette, Indiana
ependydad wrote: lpxguy wrote: Scott_85 wrote: I like that idea but I don't want to remove my hitch cover do install it.
lpxguy -
![[image]](http://i51.photobucket.com/albums/f398/GMtech45/IMG_01401_zpsd07ef2e6.jpg)
Have a simular setup... used 2x2 angle iron 6" long... rec tube is 6"... bike rack is a 914 Thule that holds the bike wheels.. rack will tip down which helps with loading bikes...
HTML
ependydad
Here and there
Puddles wrote: Have a simular setup... used 2x2 angle iron 6" long... rec tube is 6"... bike rack is a 914 Thule that holds the bike wheels.. rack will tip down which helps with loading bikes...
Thanks, Puddles. The 2x2 angle iron means each side is 2"? (Sorry, I'm a computer guy- my father-in-law is the mechanical one.)
I have a Thule rack that the bikes hang from. It'll have to do for a while.
I've also been looking at an ATV cover put on them to protect from bugs and stuff.
Puddles
Lafayette, Indiana
ependydad wrote: Puddles wrote: Have a simular setup... used 2x2 angle iron 6" long... rec tube is 6"... bike rack is a 914 Thule that holds the bike wheels.. rack will tip down which helps with loading bikes...
Yes, on the 2"... the hanging rack will work, but it'll be way up there to load... great to remove and install on the truck for side trips on the bikes... I looked for a cover also... ended up going to a canvas shop that makes boat, grain wagon covers. Has grommlets all around the bottom so that I can lace it below the bikes... needs to be tough stuff, lots of wind up there... cost $180.. Travel Safe
