Open Roads Forum |
Print | Close |
Topic: Safety Chain link being crushed by hitch when turning |
Posted By: upontheridge
on 02/20/14 09:16pm
I was getting trailer ready for a first spring trip and noticed that the first link of the safety chain on the trailer side is almost busted in half. I need to move trailer from storage area to house and decided to put a repair link on for extra measure. It got slightly smashed as well. Chain is getting pinched between trailer safety chain connector on the end of the trailer tongue and the lower part of my equalizer hitch. Trying to decide how to fix. Should I have safety chain connector welded to a different position. Not sure how to change the Equalizer hitch unless I could somehow raise the ball on the hitch. Chain is being pinched with just a 40-45 degree turn. Pic of smashed safety chain ![]() Pic of hitch. Safety chain is hitting the wing area at the end of the hitch where you see a bit of rust next the progress name. ![]() Moderator edit to re-size pictures to forum limit of 640px maximum width. * This post was edited 02/21/14 10:00am by an administrator/moderator * |
Posted By: Old-Biscuit
on 02/20/14 10:45pm
Have them relocated........welded to a different spot. Afterwards.......a wire brush and can of spray paint and attack those rusted areas Is it time for your medication or mine? 2007 DODGE 3500 QC SRW 5.9L CTD In-Bed 'quiet gen' 2007 HitchHiker II 32.5 UKTG 2000W Xantex Inverter US NAVY------USS Decatur DDG31 |
Posted By: Greydennyhawk
on 02/21/14 04:47am
Is the chain also too short?
Denny, Rosie and Josie the Beagle 2016 Allegro 36 LA 2016 Mazda 3 |
on 02/21/14 05:48am
Rewelding to a different spot was my first thought but when I called RV dealer about it they were hesitant to reweld. Trying to decide if I should take it to them for reweld or just find a welder that will do the job. Reading about safety chains everyone says the location of the holder is the best location vs on ibeam under the tongue. With the weight distributing hitch the safety chains will probably never see action unless the hitch pin would break. The chains are not to short if anything they may be a tad long. |
Posted By: We Cant Wait
on 02/21/14 05:53am
Having had the same hitch set up on 2 previous TT the only way I can see that someone could crush the safety chain is if they were jack-knifing the unit all the time while backing in. Do you have a REAL tight back in spot while camping?
Posted By: Dick_B
on 02/21/14 06:45am
X2 on the chain being too short
Dick_B 2003 SunnyBrook 27FKS 2011 3/4 T Chevrolet Suburban Equal-i-zer Hitch One wife, two electric bikes (both Currie Tech Path+ models) |
on 02/21/14 06:56am
upontheridge wrote: ![]() Rewelding to a different spot was my first thought but when I called RV dealer about it they were hesitant to reweld. Trying to decide if I should take it to them for reweld or just find a welder that will do the job. Reading about safety chains everyone says the location of the holder is the best location vs on ibeam under the tongue. With the weight distributing hitch the safety chains will probably never see action unless the hitch pin would break. The chains are not to short if anything they may be a tad long. You don't go to a RV Dealer for a weld job. Go to a welder or to a trailer shop. |
Posted By: CEddy
on 02/22/14 02:05pm
I have a very similar problem with my setup- same Equal-i-zer hitch, same stupid V-shaped chain attach point under the coupler. My chain hasn't been crushed as bad as yours, though. For the record, the current chains have plenty of length, and I wouldn't say I've 'jack-knifed' my trailer any more than normal. I'm relocating my chains to the inside of the A-frame (new chains and hooks while I'm at it). I'm using bolt-on 12,000-lb D-rings as attachment points. There are also weld-on varieties if you're so inclined. After the new chains are on, the old attachment point will get cut off. Have you also had the issue where a link will get hung under the hitch head when unhitching and pick up the back of the truck? Wore my arm out cranking the tongue jack a few times before I figured that one out! 2006 Coachmen 30TBS 2004 F-350 SRW PSD |
Posted By: Bmach
on 02/22/14 11:37pm
Old B why would you not go a an rv dealer for a welding job?
on 02/24/14 09:35pm
CEddy wrote: ![]() I have a very similar problem with my setup- same Equal-i-zer hitch, same stupid V-shaped chain attach point under the coupler. My chain hasn't been crushed as bad as yours, though. For the record, the current chains have plenty of length, and I wouldn't say I've 'jack-knifed' my trailer any more than normal. I'm relocating my chains to the inside of the A-frame (new chains and hooks while I'm at it). I'm using bolt-on 12,000-lb D-rings as attachment points. There are also weld-on varieties if you're so inclined. After the new chains are on, the old attachment point will get cut off. Have you also had the issue where a link will get hung under the hitch head when unhitching and pick up the back of the truck? Wore my arm out cranking the tongue jack a few times before I figured that one out! I am trying to figure out why KZ the trailer manufacturer would put the safety chain attachment point in a place that would interfere with hitch. Planning to take to a welding shop to have them weld something under the bottom of the aframe on each side to attach safety chains. Trailer is only a year old so hoping to use the same chains and hooks minus a link. Have not ever had a problem with chains getting stuck in hitch head. Thought about a bolt on arrangement but figured a weld would be stronger. Haven't seen any bolt on work from the factory and not crazy about drilling the frame. |
Print | Close |
