RV.Net Open Roads Forum: What did you do to your truck today?
 > What did you do to your truck today?
Page of 48
AKSuperDually
Kenai River, Alaska
Posted: 03/11/14 12:40am Link  |  Quote  |  Print  |  Notify Moderator
I love cruising through the "what did you do to your camper today" thread, I figured I'd add a "what did you do to your truck today".
I'm sure that many of you are like me....and your truck that you use to haul your camper gets a lot of special attention to make sure it's in tip-top shape for your adventures.
I'll start out.....
Today I mounted 2 PIAA 520 Fog lights and 2 PIAA Driving lights to my winch bumper, and aimed them.
This evening, I received a box containing torklift stableload bumpstops. Those will have to wait for another day....we've got a blizzard going on here.
2000 Ford F350 DRW 4x4 7.3L
2003 Arctic Fox 1150
Terrick down Under
Australia
Posted: 03/11/14 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Funny you should ask...
We have been trying to get time to renew all the brakes, So off came the front dually hubs, bearings, pads and callipers, rear drum, seals and linings. Replaced the whole lot with new. As many of you would know..."just a quick job". Especially when the rear seal had been gone for about 3 months, what a mess to clean up. When I walk out the back I can still smell the diff oil and brake dust.
Now it should stop, when I tell it to!
Next is to find some longer air bags, to cope with the suspension travel.
Good idea for a thread.
msiminoff
Silicon Valley, CA
Posted: 03/11/14 01:29am Link  |  Quote  |  Print  |  Notify Moderator
For the past few days I've been working on an HID retrofit project for my Ram… trying to squeeze Acura TL bi-xenon projectors into the stock headlamp housings. It's become a fairly big undertaking, not so much the mounting part but making the whole assembly look like a factory install and have enough adjustment to get the beam cut-off aligned perfectly. I think that I have another week's worth of work to do in order to get it all buttoned up (I've only got a couple hours each night after the kids are in bed).
Cheers,
-Mark
* This post was edited 03/11/14 07:25am by msiminoff *
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
ata3001
Niagara Falls, NY
Posted: 03/11/14 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Replaced the leaking power steering oil cooler, 2 hoses that were leaking that go to it & replaced the wiper motor. POS truck!!!
Ron & BJ
2008 Dutchmen Freedom Spirit FS180 w/full factory dark tinted glass. (9 .yrs w/o any issues)
2014 Chevy Silverado LT Dbl cab, 5.3 L, 4 WD, tow pkg, max payload pkg, Prodigy
korbe
California
Posted: 03/11/14 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I adjusted the clock to coinside with the recent time change.
moomps
minnesota
Posted: 03/11/14 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Once again, I ran into the box containing my new trailer hidge. If winter ever ends here in Minnesota, I will quit kicking the huge box and actually take the time to get it installed. And while I'm under there, I will also install the airbags that I bought last fall. Hopefully all of this will occur prior to uncovering my TC for the year.
deltabravo
Spokane, WA
Posted: 03/11/14 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I bought another one:
2006 CCSB 4WD LT3 option package with the LBZ Duramax
~DJ~
Boise, Idaho
Posted: 03/11/14 08:10am Link  |  Quote  |  Print  |  Notify Moderator
WOW!! You should go buy a lottery ticket with luck like that one your side!! Great find!!
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
mooring product
Pompano Beach Florida
Posted: 03/11/14 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I improved my MPG and HP numbers...DPF off and RaceME Pro tuner added.
Averaging 13mpg in the city and got 17mpg on my last trip (unloaded)
Did this about 4 months ago...
Flo pro by MooringProduct, on Flickr
Pete
2012 RAM 3500 Mega DRW. Stable Loads and Torklift tiedowns.
2006 Lance 881 Max.
mike mck
phoenix
Posted: 03/11/14 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I guess at 241K miles it was time. How about a new trans in the 99 F550 on the way back to AZ from Ca.
Big thanks to TCM motor in Yucaipa Ca.
* This post was edited 04/10/14 11:52am by an administrator/moderator *
Page of 48
