RV.Net Open Roads Forum: What did you do to your truck today?
 > What did you do to your truck today?
Page of 45
Bedlam
PNW
Posted: 10/04/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a tower of Toyo M655's sitting in the garage waiting to be mounted. We are spending some time on the Oregon Coastal Dunes and will try to get this done between trips. 7 by 82 lbs is much easier to move around on a furniture dolly than rolling one at a time.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
JoeChiOhki
Sauvie Island, OR
Posted: 10/05/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Continued my search for a junkyard for a new driver's door, dim-bulb moment and forgot I was parked next to a column in parking garage and ran the driver's door into it (The door was already slated to be replaced, since it has a crack through part of the window frame, this just stepped up my timeline since the door sticks a little now when opening it).
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
n0arp
FT
Posted: 10/05/21 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Are you running the OE 225/70R19.5s? What gearing do you have?
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
Bedlam
PNW
Posted: 10/05/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Currently, I have the 225's with 4.44 gearing. My Toyo's are 245's which will make cruising RPM a little less. 65 mph is 2000 rpm in stock trim.
n0arp
FT
Posted: 10/05/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have 4.89s and didn't care for the 225s with them. With the 245s, you'll effectively be around 4.28, which should be really nice.
jimh425
Western MT
Posted: 10/05/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
What width rims are you running?
jimh425
Western MT
Posted: 10/05/21 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced two roof plumbing roof vents, and found my running light gremlin. It turned out to be the plug, again. For some reason, the one in the bed doesn’t like to stay in place sometimes. I think it’s the camper moving in the bed.
I have another potential issue to checkout tomorrow. It looks like some of the weather protection near the generator on the bottom has come loose or is damaged from weather. I guess I’ll take a better look in the AM and maybe seal with bedliner etc.
dhull
Some Lake Some where
Posted: 10/05/21 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Truck bed liner...
I just used it on the wing area of ours. It'll be impervious to road spray now. Was Luan covered with contact paper stapled around the edges. Yea that'll hold back water. Used Herculiner, it's awesome!
specta
utah
Posted: 10/19/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Washed the truck and camper inside and out.
Resealed every compartment door and the three interior doors that access the wheel wells.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Buzzcut1
Norcal
Posted: 10/19/21 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Pulled off the outer dually wheels. Taking them to the shop for new rubber before we take off on a 5000 mile trip in two weeks (already put new tires on the inners)
edit:
4 new tires in place for the trip
* This post was edited 10/20/21 09:18pm by Buzzcut1 *
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Page of 45
