RV.Net Open Roads Forum: What did you do to your truck today?
 > What did you do to your truck today?
Page of 49
Posted: 06/05/22 10:54am Link  |  Quote  |  Print  |  Notify Moderator
S Davis wrote:
Installed a 51 Gallon aux tank for a total of 87 gallons.
Nice clean install!
But why all the extra parts and filter? Not down with gravity fill?
What’s the top line off the tank for?
2017 Heartland Torque T29
Ramblin' Ralph
Central California Coast
Posted: 06/07/22 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Got on the road for Ramblin' 2022 (my 17th year)! First stop at an RV Park in Gilroy, CA. This weekend I'll start a one week campout with my 2 kids in the beautiful E Sierra. After that TBD, but to heck with gas prices!!
Safe travels to all,
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 100 Ah LiFePo4, 225 watt solar
My RV Travels Webpage / Yearly Campsite Map / 740 Campsites / YouTube Videos /
Instagram
JoeChiOhki
Sauvie Island, OR
Posted: 06/10/22 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thunked the blower motor for the hvac systems with the tire checking stick to get it unstuck again, because I'm a procrastionator on fixing small non-critical stuff when I have big ticket cost repairs coming up very shortly.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
7.3driver
Central Texas
Posted: 06/16/22 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Weight truck/camper
Truck: 1999 F350,crewcab, dully, 7.3 w/automatic, fuel tank full (36-37 gal.).
Camper: 2000 Bigfoot 25c10.6, 1 battery, no propane tanks, 2500 generator and foam mattress. Other wise empty.
No driver.
10660 lbs.total. Front axle 4140 lbs. Rear axle 6520.
Max 11200 lbs on the door tag.
jimh406
Western MT
Posted: 06/16/22 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
7.3driver wrote:
No driver.
Must be hard to get anywhere. [emoticon]. Sorry, I couldn't resist.
S Davis
Western WA
Posted: 06/17/22 01:22am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Nice clean install!
I wanted a filter to catch the condensation from the metal aux tank before going into the main tank, and while I was at it decided to add a pump. It is on a 15 minute timer and will pump a little over 7 gallons before shutting off. The pipe on top is a vent with roll over valve.
specta
utah
Posted: 06/18/22 07:12am Link  |  Quote  |  Print  |  Notify Moderator
7.3driver wrote:
Weight truck/camper
No driver.
Fully loaded.
Front - 3620 rating - 4400
Rear - 7040 rating - 6200
GVWR - 9500
Truck with empty camper - 9980
Did I mention I love my new shocks? [emoticon]
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
KKELLER14K
BEAVERTON OREGON
Posted: 06/19/22 12:08am Link  |  Quote  |  Print  |  Notify Moderator
I upgraded from an old style digital that was failing...(10 years old), to the new style 7 color. They also have better sending transducers and in this application, I used a banjo bolt with an upgraded snubber valve right at the vp44 pump. At the rear of the filter housing, I went with another banjo bolt with the old school stone snubber and a tradition gauge (glycerin filled), that shows me pump pressure pre filter. Truck is 2nd gen cummins with a ddrp FASS fuel pump...so far so good.
srschang
Western NY
Posted: 06/19/22 09:16am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2 year old Northstar 12 STC with a Midi Heki skylight. We got back from a camping trip last week, and I unloaded the camper and started washing. As I was washing the front, I notice what looked like a crack on the frame of the skylight near the hinge. Climbed up on top, and sure enough, the skylight frame was broken the entire length from hinge to hinge. Not sure what happened, as we have never opened the skylight since it was new, and it didn't show any signs or scratches like I hit something.
So after a little research and finding out a replacement window & frame is over $1000, I decided to see if I could fix it. I used 3M Panel Bonding Adhesive, I guess this is what car door skins & other body parts are installed with instead of welding these days. My buddy that owns a body shop swears by it.
I was able to return the cracked plastic to stronger than original. Luckily this part of the hatch isn't visible when the hatch is installed.
Still not sure what caused the cracking, but I do remember when we got home from the trip, I was surprised to see the window latch bar Under the latch button instead of above the latch button as usual. Maybe the hatch was flapping in the wind on our trip home?
Anyway, glad I caught it as we're leaving on a 12,000 mile trip from Buffalo, NY throughout the Pacific Northwest, up to Alaska and back starting in a week.
* This post was last edited 06/19/22 09:41am by srschang *   View edit history
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
notsobigjoe
southeast
Posted: 06/19/22 11:21am Link  |  Quote  |  Print  |  Notify Moderator
This should be in the product description as these things are insanely over priced! [emoticon]
Page of 49
