RV.Net Open Roads Forum: What did you do to your truck today?
 > What did you do to your truck today?
Page of 49
ticki2
NH
Posted: 06/23/22 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Mounted her on the truck yesterday for the season . Removed steps to reseal and urethane the exposed underside of floor at door . Replaced broken handles on kitchen faucet . Found small leak at faucet valve so replaced the O rings, all better . Checked all systems , water , propane , fridge and electric , all good to go . Next is a little interior cleaning , exterior wash , then pack . Heading to friends for the 4th in the Adirondacks for a week
'68 Avion C-11
'02 GMC DRW D/A flatbed
specta
utah
Posted: 06/23/22 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
We need a like button. [emoticon]
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
PastorCharlie
NC
Posted: 06/25/22 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Last this forum needs is to be like fakebook.
specta
utah
Posted: 06/25/22 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
o
It would be nice to like a comment or picture without having to type one out.
To each their own.
TxGearhead
Posted: 06/26/22 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
notsobigjoe wrote:
Grit dog wrote:
Technically, it's still a Chevy! [emoticon]
Funny you should say that. I thought it WAS a Chevy when we bought it.
Someone had changed all the badges and trim to Chevy.
And I was so involved with looking at the truck itself, didn’t even give the title a second glance.
First clue was when I removed the tailgate trim panel ,also replaced with a Chevy one, and the original appearing tailgate had GMC stamped in it.
Further inspection showed the glove box tag with “Sierra” package.
And the grill is the aftermarket one you see in the pic, so that was no clue either. I re-used it and just fitted a GMC logo to it.
That's a good looking truck. I had a semi-rare 1982? Chevy K20 Suburban. Loaded with what appeared to be all available options, even quad shocks on the front axle. I drove to work and on hunting trips. Had a couple local boys put a cheap but decent paint job on it. My son was in the 11th grade and wanted it bad. I "sold" it to him. Of course, he put a lift kit and Buckshot Monster Mudders on it. Of course he took the 3rd row back seat out. And of course, the Turbo Hydramatic 400 had to be rebuilt. When he went off to college I traded him back a 1991? Chevy Sport Truck, which was a SS454 clone. Wish I had them both back.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
notsobigjoe
southeast
Posted: 07/03/22 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
The Cheyenne and Silverado are the exact same truck with different trim. They're both Chevy's but it's a good example of parts switching and marketing nonsense... The Silverado was a top of the line truck but the Cheyenne was a more basic truck. I know that all parts don't match but I've been replacing parts on these two trucks for decades and I've never had a mismatch between the part numbers for both. I believe this is "somewhat" true between the Chevy and GMC lines as well. Also with Cadillac and GMC.
This is an interesting short article about the basic differences between the GMC and Chevy truck line. There is a wealth of information concerning parts exchanging between the two on many forums. Just adding to the conversation.... It looks great!!!
https://www.cjponyparts.com/resources/gmc-chevy-connections
specta
utah
Posted: 07/03/22 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
GMC was GMC and Chevrolet was Chevrolet until 1973.
That was the year that they became one.
specta
utah
Posted: 07/03/22 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
I drove it down to the museum to pick up my mail.
Hopefully the 410 goes in next week.
S Davis
Western WA
Posted: 07/04/22 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Finished the aux bed tank install, got three more holes through the cab floor with water tight connectors, one for the 14/2 to the fuel pump and two extra for 10 gauge so cord for 120 volt 30 amp in and out for the 2800 watt inverter. Wired the pump timer to the pump and to the low voltage fuse panel in the cab, twist the timer for 30 minutes and it will transfer about 15 gallons and shut off.
Bedlam
PNW
Posted: 07/06/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Changed out a flat on an inner dual:
To free the inside rim took a little more persuasion but no hammers were involved.
So some blocks of wood that are normally used for leveling, a couple of spare ratchet straps, 12-ton bottle jack, electric impact wrench with 22mm socket, torque wrench with extension, claw hammer to remove hub cap and some time was required to get this 9-ton truck rolling again.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
Page of 49
