RV.Net Open Roads Forum: Battery upgrade.. how in a 4winds with....
 > Battery upgrade.. how in a 4winds with....
bigcitypopo
Ventura Co. - CA
Posted: 03/30/14 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
an outside battery tray, that will hold one group27...
move the batteries inside and use AGM?
it a 4winds Majestic 23... it is my mom's she got it from reserve america.. its been a great coach. the single skyline battery in it is on its way out. it only holds 12.0v after a full charge.
any recs would be great, or any upgrade ideas?
i'm just now learning the quirks of her class C,
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
pianotuna
Regina, SK, Canada
Posted: 03/30/14 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I chose to have one of the out door storage compartments modified to carry the weight of four batteries. Much cheaper than buying AGM chemistry.
Regards, Don
path1
Varies with weather
Posted: 03/30/14 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Majestic 23
I have 23P model. I can only get 1 group 27 the way mine is also. I have not done this yet but have planned for upgrade (as far as projects go). I'm going mount the other battery with this. Have heard of no complaints. https://www.etrailer.com/RV-and-Camping/Tork-Lift/TLA7727.html
One reason for holding off is price, which is crazy. It's not the $152.00 it's what I get for the money. I've had my eye out for metal box size of battery and then make a hook to fit on frame.
* This post was edited 03/30/14 10:18pm by path1 *
bigcitypopo
Ventura Co. - CA
Posted: 03/30/14 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
Pianotuna.... I was thinking the sme... But her coach already has limited storage....
Path1... That thing is neat... I'm gonna crawl under that rig and look again
Tom_M
New Hope, MN
Posted: 03/31/14 05:36am Link  |  Quote  |  Print  |  Notify Moderator
If you mount a battery on the frame under the coach, it would make it very difficult to check water levels on a flooded cell battery. This would be a good reason to consider AGM batteries. You can not mix flooded cell and AGM batteries, so this would mean that you would need to buy two AGM batteries.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
super_camper
Ontario, Canada
Posted: 03/31/14 06:56am Link  |  Quote  |  Print  |  Notify Moderator
This is what I did and it is a pain in the a$$ to check the batteries but it works!
bukhrn
Lanexa, Va
Posted: 04/01/14 07:48am Link  |  Quote  |  Print  |  Notify Moderator
I don't have any input on your question, but I have a question of my own, you say your Mom got this coach from Reserve America, are you talking about the Reservation site? I wasn't aware they sold RV's ?? [emoticon] [emoticon]
2007 Forester 2941DS
2014 Ford Focus
Snowman9000
IL
Posted: 04/01/14 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Looks like I didn't save my photos, but I had the same thing on my Trail Lite B+. I had a welder fabricate a second battery tray, hung from the frame with straps similar to the first one. AGMs would be perfect for that setup.
PS, I had to go back and have him add braces across the straps except for the side we left open to pass the battery through. Without braces it was too wobbly with the weight of the battery hanging in it. Eventually it would have cracked somewhere.
Currently RV-less but not done yet.
BruceMc
Oregon - Willamette Valley
Posted: 04/01/14 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Here was my solution to the single battery tray in our Four Winds. There should be room, but it is tight. As you can see in the original post, I made mine with a slide out arrangement so it makes it easy to check the levels, etc.
Good luck!
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
WA7NDD
Rigby, Idaho
Posted: 04/01/14 10:05am Link  |  Quote  |  Print  |  Notify Moderator
BruceMc: Like your MH it is identical to mine except mine is a 1998 22rk and my battery box is farther back, but with the same lack of room for two 6 volt batteries. I was looking at some type of modification also. Thank you for the ideas. There is a picture in my profile, be on the Oregon coast this June, again.
1998 Four Winds 5000 Rigby, ID
