RV.Net Open Roads Forum: Class C Motorhomes: wandering front
 > wandering front
Hank85713
Tucson, Az
Posted: 06/02/14 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of years ago I read a road test on setup similar if not the same as I have. I cannot find the article so Need to see if anyone else has encountered and cured.
In the article they talked about light front end and wander. On this 2012 winnebago aspect I have the same issues. Rear bags aired to 50psi and did help some but the front is light and I am thinking it needs an improved or dual setup steer stabilizer.
So has anyone else encountered and how did ya deal with it? van has just under 6000 miles on it.
Thanks Hank
Explorer1016
Missouri
Posted: 06/03/14 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Hank, sounds like a typical case of front end alignment issues. I didn't see the article or even own the same rig you have but my 08 F550 was doing the same thing and I had the caster set to about -1 degree ( I think that is correct) and it took the light or over steer out of the rig. It drives straight down the road now without having to over correct constantly. I have also setup several off road Jeeps with big axles, big tires and complicated suspension geometry and if the caster is set too far positive the Jeep will wander all over the road. It is called over steer and is a symptom of incorrect caster. Consequently if the caster is too far negative it is very difficult to steer and make corrections, this is under steer. Hope this helps you out.
2008 Host 300 Super 'C'
2008 Ford F-550 Chassis
Diesel
4x4
Lariat crew cab
20' enclosed car hauler/garage
'87 Jeep rock crawler
Turbo'd
rvten
Crossville,TN
Posted: 06/03/14 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Are you towing a trailer or car on a dolly?
Have front end alignment checked?
Steering damper?
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
j-d
Sunny Florida USA
Posted: 06/03/14 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Hank, What are your:
Axle Weights
Tire Pressures
Coach Length and Wheelbase
Aspect Model Number
Alignment Numbers esp. Caster and Toe
And:
Any chassis/steering upgrades so far?
Are you towing a Vehicle or Trailer?
Alignment-Wise: On the E-Series, Road Wander is a result of too little Caster and not too much. Mid-range spec for E is around +3 and we're finding +5 tracks much better. The F-Series must be different because if an E went less than +3 let alone negative you'd have to tow it or park it.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
Explorer1016
Missouri
Posted: 06/03/14 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Axle Weights
Tire Pressures
Aspect Model Number
And:
j-d, +5 degrees sounds crazy to me. They must really have those Fords loaded heavy over the front axle to cause you to put that much caster in one.
j-d
Sunny Florida USA
Posted: 06/03/14 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I know. Call it counterintuitive, but... An OP here called Harvard tore this issue apart trying to get his E450 to track AFTER he paid a shop to align it. What he finally did was crank his adjustable offset upper balljoint bushings up by 2* Caster over where the shop left it. Went from around 3* to +5.0*L and +5.3*R and got it to track like a passenger vehicle. Everybody who's gone with his suggestions has reported vastly improved tracking.
But I have personally been to The Mountain. Visited the Mecca of RV suspension tuning. Hendersons' Line-Up in Grants Pass OR a couple weeks ago. I mentioned Harvard's 5* caster and John said "Sure. I worked in the shop 25 years and did lots of alignments. That's what we do." That settles the debate far as I'm concerned. John also didn't see Class C tracking as the major issue we hear about here. Said a Rear Track Bar and Safe-T-Plus steering stabilizer usually gets them driving well. That's another point of note about Henderson. They've chosen the best components for each item. They're big on Roadmaster for sway bars and other items. But they go Safe-T-Plus for stabilizers, not Roadmaster's Reflex competitor. Henderson owns SuperSteer, so those components, like Track Bars and bellcranks for Class A are their own products.
I'm told that too much Caster will make one shimmy, but I'm not convinced an E-Series, which is what we're discussing here, can be set high enough to reach that point with the alignment kits that are available. Hank is on track trying to use some rear suspension lift to shift weight to the front axle but there's only so much that an inch of lift will do.
I'm asking what the Aspect Model is so I can look at both Length/Wheelbase AND Floor Plan. I'm forming the opinion that handling problems originate from the Floor Plan. What? Lemme 'splain: Marketing tells Styling that a Walk Around Rear Queen layout, perhaps with a Slide back there, is what sells. So don't just do that on the 31-footers. Put it on the 27's and 29's too. What's ahead of the bedroom? Bath and Kitchen. The Fridge and the Shower offer a place for the wheel well bulges, so Styling tells Chassis what the Wheelbase should be. Shorter coaches get the same "rear clip" as longer ones and it can impact axle loading which has a relationship to tracking.
Explorer1016
Missouri
Posted: 06/03/14 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Very nice detailed explanation.
j-d
Sunny Florida USA
Posted: 06/03/14 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. We're making progress in understanding handling/tracking issues. In some ways, just catching up what the professionals haven't told us. Henderson didn't hide secrets, more like nobody asked.
I know F-Series drives differently than E-Series, and for the better. A friend had an F-250 short box towing a Fiver and then an F-350 long box carrying a heavy BigFoot slide-in. I got to drive both over long distances. Both were SRW V10 Extra (not Crew) cab. Both tracked better than a Class C.
Usually we can help Class C owners with Ford chassis get improvement. Then there are some who testify they didn't have to do anything to drive OK. Waiting on Hank's info, especially weights.
Harvard
51.6N 114.7W
Posted: 06/03/14 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to my experience with adding more +Caster
RambleOnNW
Pacific Northwest
Posted: 06/03/14 09:15am Link  |  Quote  |  Print  |  Notify Moderator
The alignment shop I went to a few years ago set the caster to +5.2 deg L and +5.7 deg R. This is not any run-of-the-mill alignment shop, this is the shop other alignment shops send their work to when they can't figure it out. They are well aware from their experience of the Ford E350/450 tendency to wander.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
 > wandering front
