RV.Net Open Roads Forum: Tech Issues: Harbor Freight Battery Maintainer Mod
 > Harbor Freight Battery Maintainer Mod
msiminoff
Silicon Valley, CA
Posted: 09/27/14 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a TT that I store at a remote location during the winter and I bring the group 31 AGM battery home with me. I have a charger to ensure that it is at 100% SOC before it gets set in the corner of the garage, but I have been looking for a float charger to keep it at the mfr's recommended float voltage of 13.4-13.6V.
I found a coupon from Harbor Freight for one of their 69955 Automatic Battery Float Chargers for only $5 and figured it was worth a shot to see how well these little maintainers perform. However when I hooked it up it was apparent that there were two significant flaws; 1) The LED power indicator would illuminate even when mains power was disconnected and 2) the float voltage was in the 13.8-13.9 range.
After cracking the case open I realized that both of these issues could be easily remedied with components I had in sitting on on my workbench…. I added a generic 1A Schottky diode to the output wiring which prevents the battery from powering the LED in the event of a loss of AC power. I replaced resistor "VR1" with a 100 Ohm 22-turn trim-pot which gives me control over the charge voltage.
I'll keep an eye on the voltage & current over the next few weeks, but at the moment this looks like a promising battery maintenance solution.
Cheers
-Mark
Diode & potentiometer installed.
The trim-pot can be accessed from outside the enclosure.
AGM Battery float-charging at 2.41mA and 13.47V.
* This post was edited 09/27/14 05:04pm by msiminoff *
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
westend
Shorewood, MN
Posted: 09/27/14 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Nice mod.
i've been thinking a 12v wallwart transformer could be purposed for this use. I see the circuit in the HF model you used is really simple. I may have to investigate this further, I have more than a few wallwarts laying about.
'03 F-250 4x4 CC
harold1946
surprise Az.
Posted: 09/27/14 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
An AGM battery does not need a maintainer if fully charged when put in storage. The self discharge rate is only 1-2% per month.
Maintaining an AGM battery at 13.8-13.9 you will be risking thermal runaway, that will destroy the battery.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
mena661
Posted: 09/27/14 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Nice mod!!!
Trojan L16 6V's 740 Amp-hours
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/27/14 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
There are a bunch of 800ma 15 volt wall warts out there. One 3-amp silicon diode on the positive, another on the negative will drop voltage around 1.5 volts. Rendering a 13.5 final but the 800ma unit will sag to around 13.3 - 13.4
Even unregulated warts can be used if they are 800ma. Silicon or shottky diodes can used to fine tune finishing voltage. Verify voltage after 24 hours.
VRB construction only has problems with thermal runaway if a wattage threshold is breached in combination with excessive internal temperature. I'm afraid 12 watts is far too menial an energy source to provoke catastrophe. By maintaining a finishing float voltage in the 13.2 to 13.5 range
pkunk
Questa, NM
Posted: 09/27/14 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
westend wrote:
Nice mod.
I use a 1A 12v wallwart modded with aligator clips. Works great [emoticon]
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
RJsfishin
Winston Or.
Posted: 09/28/14 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Someone here had a HF maintainer smoke a battery,....but mite have been more to the story. Both my HF maintainers sit at 13.3 never more than plus/minus 1/10
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
msiminoff
Silicon Valley, CA
Posted: 09/28/14 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Yes I do agree (westend, Mex', & phunk)… a similar result can be achieved with a wall-wart. But keep in mind that my total investment is about $6. There's no way I could assemble all of the components myself for anywhere near that price. A new regulated or switching wall power supply alone would cost me $10-15, and still wouldn't give me the ability to adjust the charge voltage or limit the current to my personal preference (ie. battery mfr's spec').
This super-cheap HF maintainer incorporates a 78XX linear voltage regulator and a TIP41 to regulate current. In addition it has a S9013 transistor to turn itself off if the battery voltage is too low.
As I mentioned, in stock form it does have some minor drawbacks, specifically;
1) A fixed output voltage, which may or may not meet my needs (I have read reports from other users that indicate voltages as low as 13.1 and as high as 14.1. Mine was 13.8-13.9)
2) There is no protection to prevent the device from discharging the battery if mains power was lost (or more likely if/when the wall transformer fails).
These 2 issues are easily fixed with the addition of one potentiometer and one diode… about $1 worth of parts.
The fact remains that this maintainer does not address temperature compensation at all [emoticon] Conveniently I live in the SF Bay Area where we have very modest seasonal temperature change. My workshop is climate controlled and the voltage I selected (~13.45V) will be fine for up to around 80ºF.
Ha, I guess I should said "in storage for 11 months".
At any rate, a well-regulated (bonus points for temp compensated!) float charge is always preferable over leaving a battery to self-discharge while in storage.
Cheers,
-Mark
westend
Shorewood, MN
Posted: 09/28/14 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Mark,
Good stuff and the financials are evident, I didn't know they gave the things away. Heck, a good set of clips approach $5.
I'm looking around in the bins to see if I have a bourns pot that will do the job.
Up here, in the Great White North, battery maintainers are like gold. I can think of three batteries I have that could use maintainers.
mena661
Posted: 09/28/14 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a couple of these maybe I'll try the same thing just for the hell of it. Great info and thanks for the post.
