RV.Net Open Roads Forum: Can you hook two different kinds of generators together?
 > Can you hook two different kinds of generators together?
Iamjustaniceguy
Pennsylvania
Posted: 10/27/14 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Temporary Tattoo and Face painting business so now we spend pretty much all summer "Camping" either at fairs working or relaxing when we can. We got a used KZ Sportsman fifth wheel this fall and I would really like to get a new larger generator (Looking at a Yamaha EF2400IS). What I/we would like to know is has anyone ever hooked a Yamaha and a Honda generator together to power a camper? I honestly think the Yamaha would power everything but it might be nice to have our old Honda 2000i to help out if needed. We know the Honda won't work for everything at least with our old camper it usually wouldn't handle the air conditioning start up.
So if anyone has ever hooked up a Yamaha 2400IS and a Honda 2000i we would love to hear how it worked and what cables you used.
Thanks!
Gary 50
Pam (women have birthdays not ages, ">)
Kids:
Jedediah 21 in the army now
Caitlin 17
Gabrielle 14
Jayco KIWI 17A, Cancel that we now have a 2007 Jayco 232 and love it so far! Dodge RAM 1500, Crew Cab, and yea it has the 5.7L HEMI! ">
pianotuna
Regina, SK, Canada
Posted: 10/27/14 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I think the Yamaha 2400 can not be paralleled.
Regards, Don
old guy
Oregon (pronounced Or e gun)
Posted: 10/27/14 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think I would mix brands together.
ryanw821
Minneapolis, Minnesota
Posted: 10/27/14 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
Without a way to synchronize them (something a parallel kit does for "matched" generators) they could be out of sync and possibly deliver up to 240v to your 120v system, which would be bad, very bad.
You could however safely run two independently, run RV shore power into 1st genny and run some loads off an extension cord leading to the 2nd genny, nothing wrong with that.
TT - 2015 Palomino Puma 26RLSS
TV - 2017 Nissan Titan XD (Cummins diesel)
2oldman
New Mexico
Posted: 10/27/14 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
the parallel kit is nothing but wires.
Wayne Dohnal
Bend, OR.
Posted: 10/27/14 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Based on posts that I've read, the Yamaha generators have a more standard 120 volt output as compared to the Hondas that tend to run about 128 volts until heavily loaded. This means that if the generators did sync ok, the Honda would carry all of the load until it was close to overloading. Only then would the Yamaha pick up part of the load. The output voltages are incompatible, and they would not make a good combination. I've not read of anybody actually trying it. Theory is nice, but even if the risk seems small, most or all of us are too scared to take the chance of burning out an expensive generator.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
valhalla360
No paticular place.
Posted: 10/28/14 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Just make life simple on yourself. If you already have the honda get a matching honda, so you don't have to guess if you can parallel them (likewise if you were starting with a yamaha, stick with yamaha).
I'm not sure what system they use to parallel but if they don't synch up it can cause a lot of problems.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Wherever I happen to park
Posted: 10/28/14 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I would not parallel generators that are not at least the same make.
Yes, it can be done, in fact it is done every day, by professionals with the knowledge and hardware to do it,,, But that list of professionals does not include thee or me (You because if you were on that list you'd not have ask).
Best to parallel honda with Honda and yahama with Yahama
Home is where I park it.
NinerBikes
Somewhere camping
Posted: 10/28/14 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Buy another Eu2000i Honda and a parallel cable kit, and be done with it. 3600 watts on tap, when you need it. Always parallel the cables first before starting either generator. That should run everything on your 5th wheel, though not all at the same time, you might have to juggle some things being off while other items are on. A/C unit and microwave or AC and hair dryer at the same time would be big no no's.
time2roll
Posted: 10/28/14 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Never read a post of connecting different brands. You could be the first [emoticon]
Honestly... get a Honda companion and parallel kit.
Maybe even go crazy with an extended run fuel tank.
http://www.wisesales.com/bergs-dual-feed-extended-run-tank-for-honda.html
675w Solar pictures back up
