RV.Net Open Roads Forum: Truck Campers: Making an umbilical/pigtail cord
 > Making an umbilical/pigtail cord
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 11/19/14 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
My 1995 Palomino Bronco 1200 didn't come with the cord to connect the camper to the truck's electrical system. My camper does NOT have taillights or turnsignals or backup lights; just marker lights. I've got the plugs and the 4-way 16-ga bonded wire. The 7-way blade connector directions tell me which blade provides 12v to what function.
The 4-way round plug tells me nuthin'. (I DO have the very-generic owner's manual, which tells me nuthin')
The camper plug:
The control panel in case it matters:
I'm assuming I only use 3 wires: ground; whatever goes to the taillights/(markerlights); and a line that's 12v always-on?? I'm also assuming that the 16 ga wire will supply the equivalent of a trickle-charge to the battery and that's OK? I won't be running anything 12 volt going down the road.
I've asked the folks at Palomino for a wiring diagram - kind of suspect that's like asking for a unicorn. So do I wire to those 3 points on the plug that goes into the truck's trailer receptacle, then simply play "do you work now?" with the 3 wires at the camper plug?
tonymull
lake stevens, Wa
Posted: 11/19/14 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Is there only one of those outlets or are there 4? I ask because my camper has 4 of them but they are to plug in electric jacks if I ever convert to them.
Reality Check
North Bend
Posted: 11/19/14 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I'd do a quick continuity test to determine which of those is ground (one of the four prongs we'll assume). After that (once determined and hooked up), jump a hot wire to each of the other three; when the markers come on, you're got that nailed.
Determining which is the charging feed would be my next game; I'd probably just disconnect the battery, run a jumper to my tester, then use a hot wire against the remaining two prongs and see if the tester flinches.
I offer this as a layman's way to chase a solution.
'07 F550 with Link Ultraride air under an '11 AF 1150. It's either a fishing boat, snowmobiles or dual sports; something is always being towed.
Switching over to a 2016 F550 with new Ultraride air...just need to get the flatbed built.
RoyB
King George, VA
Posted: 11/19/14 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Check with ETRAILER.COM as they have everything trailer including 4-way and 7-way connector and cables etc... Etrailer also has schematics etc for all of the trailer connectors including the 4-way items
Also has vidios that are helpful as well...
This is a great company for trailer electrical parts...
Roy Ken
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
enblethen
Moses Lake, WA
Posted: 11/19/14 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
This should be the way it is wired.
Four pin round
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 11/19/14 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Four pin round
That is typical 4 pin but OP stated no turn signals/back up lights etc.
Just running lights.
OP will need to test each pin with DC power OR pull plug and trace wires
Reality Check
North Bend
Posted: 11/19/14 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Am I the only one that thinks people get so excited about answering a persons question, they don't actually read the question?
Carry on....
Deb and Ed M
Posted: 11/19/14 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Just the one on the front corner/driver's side
Deb and Ed M
Posted: 11/19/14 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, everyone - I DID go to etrailer's website, but didn't look at all the available info (missed enblethen's link). I just saw the bare wires and thought "I'll still have to guess at this".
I didn't see anyone saying that 16ga wire is useless for charging the battery a bit (or that it would burn down the camper) - so I'll proceed with "Are you the right prong?".
I don't have a battery at the moment. I'm assuming that once I connect the 12v wire to the correct prong, I'll have a smidge of electric current between the battery connectors? My multimeter will measure millivolts, either AC or DC. And I might not be able to do this for a few days.... I have to share the service bay with our "inventory"....LOL!
tonymull
lake stevens, Wa
Posted: 11/19/14 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
etrailer has an ask the expert service that can help you out probably.
