RV.Net Open Roads Forum: CP3 in Ram verses CP4 in Ford and GM
Search only in Tow Vehicles
 > CP3 in Ram verses CP4 in Ford and GM
Page of 5
labren
Langley, BC
Posted: 02/16/15 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Is there someone that could possible explain the difference in the cp3 system that is in a Ram verses the cp4 system that is in a Ford? The high pressure Fuel Pump, is it just a brand difference or an older version? Thanks for any input on this.
2014 Ram 3500 SRW 6.7 Laramie CC SB 4x4
2015 Keystone Cougar 279RKSWE
Grandpere
Gosnell, AR
Posted: 02/16/15 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to the Cummins forum that explains the differences:
Cummins forum
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
Garry&Gayle
Hemet, Ca.
Posted: 02/16/15 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I hope somebody has a better explanation than that link does.
N-Trouble
NorCal
Posted: 02/16/15 08:13am Link  |  Quote  |  Print  |  Notify Moderator
The CP3 was the predecessor to the CP4. CP3 has a 26k max PSI whereas the CP4 can hit 29k PSI for emissions purposes. The biggest difference from a consumer standpoint is in the way they fail. CP3 typically just start loosing rail pressure when they go bad. Replace the pump and your on your way again. When the CP4 lets go it typically grenades throwing metal shavings into your fuel lines and injectors. Entire fuel system has to be replaced to the tune of $10-12k if out of warranty.
A lot of new Dmax owners are putting CP3 conversions on their truck as an insurance measure.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
gmcsmoke
Butler
Posted: 02/16/15 10:34am Link  |  Quote  |  Print  |  Notify Moderator
define a lot
kzspree320
Louisiana
Both are made by Bosch. CP4 failures as stated above are huge repairs and it just takes a little bit of water. Based on what I have read in various forums, when the trucks are still under factory warranty, GM has covered these repairs and Ford generally does not. I am glad my out of warranty 6.7 Cummins has CP3. Hope this helps.
BurbMan
Islip, Long Island
Posted: 02/16/15 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Since Bosch has to know this, and assuming they can't stop the pump from grenading if it fails, you would think the OEMs would install some sort of screen or filter or something immediately downline of the pump to catch the debris. If the pump has to fail like that, so be it, but there has to be a way to contain the damage so that the fuel lines and injectors don't need to be replaced also. Make it a $2000 repair instead of a $12000 repair.
What am I missing?
2001 Suburban 2500LT 8.1L/4.10
2008 Terry TT
Hensley Arrow Hitch
Dill TPMS, CorrecTrack alignment, LT tires
Cummins12V98
on the road
Posted: 02/16/15 11:03am Link  |  Quote  |  Print  |  Notify Moderator
CP3 another good reason to own a RAM/Cummins.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ScottG
Bothell Wa.
Posted: 02/16/15 11:48am Link  |  Quote  |  Print  |  Notify Moderator
What am I missing?
I think the reason they don't do that is because a screen wouldn't do it. It would take a 2 micron filter (that can withstand 26000 PSI) to keep the debris from killing the injectors.
* This post was edited 02/16/15 12:02pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ScottG
Bothell Wa.
Posted: 02/16/15 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
I'd bet anything the Cummins will eventually use the CP4.
Page of 5
