RV.Net Open Roads Forum: Travel Trailers: Help....i have a few stupid questions....
 > Help....i have a few stupid questions....
BarneyS
S.E. Lower Michigan
Posted: 07/08/02 03:10pm Link  |  Print  |  Notify Moderator
lilbear,
I sure did not mean to make it confusing with my previous post. It sounds like you have a standard weight distributing hitch without sway control. You DO need sway control and should not tow without it -regardless of your previous good experience. You never know when some idiot is going to pull in front of you or you have to make an emergency manuver and your trailer will start to sway.
Rather than purchase a whole new hitch assembley, just add on either a friction sway control bar ( this is the least expensive and also least effective) or you can now add on the "Dual Cam" sway control to most hitches if you have the flat ends on your spring bars (which most do). The "Dual Sway" control is much more effective than the friction control and does not cost much more. Here is a web site that shows both items.
http://www.draw-tite.com/products/products/tow_wd_swaycontrol.shtml
Hope this clears up any misunderstanding.
Barney
*This Message was edited on 08-Jul-02 03:15 PM by bsmith0337*
Not towing now.
5thwheeler
Posted: 07/08/02 03:54pm Link  |  Print  |  Notify Moderator
Sometimes it gets real confusing. Take slide-outs and slide-ins. They both slide in and out but they are two entirely different animals.
lilbear
ND USA
Posted: 07/08/02 04:52pm Link  |  Print  |  Notify Moderator
Ok thanks for all the replies. I am understanding more and more. We have 2 black bars (with chains) that hook up to the side of the hitch on the trailer and right beside the ball on the truck. Dual cam is probably the way for us to go beings we already have the equalizer hitch. NOW, has anyone put one of these on and is it fairly easy?
Your all a great help! [emoticon]
BarneyS
S.E. Lower Michigan
Posted: 07/08/02 08:02pm Link  |  Print  |  Notify Moderator
lilbear,
Yes, Mike R. , a frequent poster to this forum, has installed the dual cam on his spring bars. Here is a link to his post on the subject. Make sure you read through to the 2nd page to see his final results.
http://www.rv.net/forums/index.cfm/fuseaction/thread/CFB/1/TID/224848.cfm
Barney
Bigbear
Minot ND
Posted: 07/08/02 08:27pm Link  |  Print  |  Notify Moderator
Lilbears husband here, I have a CP Products dual bar weight distribution setup, with chains. Can I attach a dual cam system too it? It will "attach directly to a round or trunnion spring bars". I am brain dumping on what the heck a trunnion exactley is! Pictures I have seen don't clear that one up for me either.
Trailer towed great in 30 mile an hour crosswind being passed by and passing semi's. Dealer tells me I don't need one and all they want is money? But lilbear is the safety person, so If I can do it on a CP Products WD system I will.
Any ideas?
Thanks in advance
Brian
BarneyS
S.E. Lower Michigan
Posted: 07/08/02 08:41pm Link  |  Print  |  Notify Moderator
Hi Brian,
The round spring bars are "L" shaped and insert into the hitch head from the bottom. The trunnion bars are square with a "T" shape on the large end which inserts into the hitch head from the front. I don't know anything about CP products hitch system so can't help you there. Perhaps you can take one of the spring bars to a hitch shop and they can tell you if the dual cam will work. Actually, if I were you, I would probably just go with the friction sway control. It can be mounted on just about any hitch and will probably serve you fine. Just about any hitch shop will have and be able to install one for you for around $100.
Barney
Bigbear
Minot ND
Posted: 07/08/02 09:06pm Link  |  Print  |  Notify Moderator
Thanks Barney
They are trunion bars. After reading Mike R's exploits mentioned in above post I wonder about doing it myself LOL.
Maybe somebody else will have messed with CP Products and have devine insight!
lynngol
Lakeville, MN
Posted: 07/09/02 07:10am Link  |  Print  |  Notify Moderator
lilbear
I installed a Dual-Cam about a month ago and the process was fairly straightforward. The only complication was raising the propane tank rack to make room for the Dual-Cam U-bolts. I used about four washers on each mounting screw betweeen the rack and the trailer tongue to accommodate the U-bolts. Just follow the directions, especially the final adjustment.
Lynn G, the Ukrainian and Sasha the wonder dog as "the Beaver"
2002 Silverado Crewcab 2500HD Duramax + Sportsman 2604P
lilbear
ND USA
Posted: 07/10/02 03:36pm Link  |  Print  |  Notify Moderator
Ok, we ordered a dual cam sway control unit. But, just to be sure, this WILL work with the weight distribution bars we have correct???
Also,FYI, we joined Camping World and were able to order and GET the Reese dual cam for cheaper than anywhere else on the net.
Call me safe conscious but, I have an 8 year old that i want to see grow up. If this Reese dual cam will help in any way then I want to use it! [emoticon]
Thanks for all your help!
Laurie
was_FunCruiser
Cyberspace
Posted: 07/10/02 06:03pm Link  |  Print  |  Notify Moderator
".... then you do the hokey-pokey and you turn yourself around, that's what it's all about...." [emoticon]
