RV.Net Open Roads Forum: Honeywell RTH5100B Thermostat
 > Honeywell RTH5100B Thermostat
2000_Kiwi
NC
Posted: 03/16/15 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
The thermostat upgrade is a very common upgrade and lots of information is available on this forum. I wanted to add the specific model I used for others that may be searching.
Honeywell RTH5100B 1025 Deluxe Manual Thermostat
I picked this specific model because it had the "automatic" switching between heat and a/c. In Spring and Fall the day and night temperatures can vary significantly.
This model is also battery operated so there is no need to power the unit separately; just make sure you keep extra batteries on hand. My next mod may be to take a variable voltage regulator (LM317) and connect it to the 7.5v supply provided for the Duo Therm and power my Honeywell.... But this is not a priority.
Please note that your wire colors may vary. With this configuration you will lose the HI/LO fan option. This will give high fan only.
There are other posts in this forum that will show you how to add a separate switch to maintain the dual fan settings.
The original analog Duo-Therm by Dometic
Duo-Therm Wiring
Honeywell Wiring
Honeywell Installed
Wiring Diagraim
It is important to note that you will need to follow the setup guide to select the correct parameters. For example: the auto feature where it switches between heat and cooling is disabled by default.
* This post was edited 03/16/15 01:11pm by 2000_Kiwi *
Dakota98
Idaho
Posted: 03/16/15 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Installed mine last Spring.
By far, an improvement over the old one!!!
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
2000_Kiwi
NC
Posted: 03/16/15 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Nice info/control center!
Fisherguy
Vancouver BC
Posted: 05/28/15 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
JUst wondering, you have the 2 'fan' wires both going to the same lug on the thermostat? If you only wantedthe high spped to work couldn't ou just vconnect the 'hi speed' wire?
If a person wanted the seperate switch for high and low he would wire the switch to that lug as common on the switch?
That seems pricey for a non prgrammable thermostat isn't it?
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
480 watts of solar
SoundGuy
S Ontario
Posted: 05/29/15 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Yes. Also make sure the switch has a centre off position and one can then start the A/C using a 2K genset and have the initial load the genset has to deal with reduced by the amount of load the fan would otherwise present ... once the compressor ramps up to speed, simply turn the A/C fan on. Works like a charm.
~ $32 US or $50 Cdn is "pricey" for a thermostat that's such an improvement over any stock bi-metal thermo? [emoticon]
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
Chris Bryant
Arden, North Carolina
Posted: 05/29/15 05:32am Link  |  Quote  |  Print  |  Notify Moderator
DuoTherm (Dometic) uses two relays for fan control on these boards- the brown fan lead switches power to the fan- this must be connected or the fan will not run. The blue high fan relay simply toggles between high and low fan, so you hook the brown wire to the new fan circuit, the blue wire will connect to this circuit via a simple switch to combine the two.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
