RV.Net Open Roads Forum: Tech Issues: Separate Alternator Rectifier For HOUSE Batteries
 > Separate Alternator Rectifier For HOUSE Batteries
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 05/02/15 09:08am Link  |  Quote  |  Print  |  Notify Moderator
All is needed is an adequate 3-phase bridge rectifier with insulated base to affix to a finned heat sink.
Three phase terminals.
One positive terminal
One negative terminal.
If the rectifier has alternate or additional terminals, skip it. For all intents and purposes it is a gizmo not the real thing. I've perused eBay and saw lots of nice rectifier bridges. Plain 5-terminals.
areddon
Canada
Posted: 10/18/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
I know this is an old post, but I am trying to figure out the wiring of my alternator to external rectifier.
Alternator is Mitsubishi 12 volt 115 Amp.
The stator has four pairs of coated wires attached to the rectifier bridge/voltage regulator/brush holder.
See photo of stator and (edit) FOUR wire pairs at [image].
Assuming it is a 3 phase output, how do I identify the three pairs that give the input to the rectifier and what is the fourth pair all about?
Thanks for any help
* This post was edited 10/18/21 09:27pm by areddon *
areddon
Canada
Posted: 10/19/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Disregard above question. I just realized that the pair of leads that is second from the right is attached to the "W" terminal which is often said to be an unrectified AC output for tachometer use. I guess that it is a fourth winding loop just for tachometer purposes. The other three pairs must be the 3 phases of AC generatedd in the stator.
MEXICOWANDERER
Posted: 10/19/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Count your rectifiers. If there are four pairs, OEM is obviously rectifying that termination. I personally disfavor unbalanced phases for the sake of the voltage regulator even if it is ECU contained. To keep this a bit less technical I have seen overheated phase windings due to a disordered phase 4 conductor. With a principal loading route still connected a total phase connection does not exist but amplified phase inequality due to small #1 vs Large #2 over long periods of time have impacts. I used to use TO5 30-amp rectifiers both anode and cathode connections to fully rectify the stator on Ford 3G and 4G units.
