RV.Net Open Roads Forum: Just got a hitch mount for my Honda 2000
 > Just got a hitch mount for my Honda 2000
Buzzcut1
Norcal
Posted: 05/10/15 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Torklift lock and load Sidekick
Easy to assemble, I will use a wobble stopper locking hitch pin to mount it to my front receiver.
I am going to head over to my buddys place and we are going to weld the tray to the receiver cross bar, as well as the y arm, bolts are to easy to unscrew. However as it is it will prevent the opportunistic campground snatch and grab
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Raften
Northern Calfornia
Posted: 05/10/15 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Very nice. After getting the first edition of the carrier I and am sure many others, wrote suggesting a version for single gen sets. I would just weld the nuts with a tack instead of welding the sheet metal.
Buzzcut1
Norcal
Posted: 05/10/15 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I'm evil. I'd rather have the thief waste a bunch of time unbolting stuff then find out it's welded in place[emoticon]
plus the nuts are nylock and I don't feel like swapping them out
RoyB
King George, VA
Posted: 05/10/15 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Is that LARGE HAND NUT the only thing holding the top strap around the Generator. Seems like that would very easy to remove the top strap. Just reach under the tray and remove the large hand nut?
I'm still with the old crowd where "OUT OF SIGHT-OUT OF MIND" is best security policy...
My 2KW Generator is secured in the tailgate corner of my truck bed and has a locked FOLD-A-COVER bed top over it. It goes where I go... Been this way since 2008...
Roy Ken
Camper_Jeff_&_Kelli
Seattle
Posted: 05/10/15 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a well built unit. Front receiver, Good use of space. Weren't you mounting bikes on the front and if so does that change? Does your super hitch have a utility receiver above the main stinger to accept racks or even the generator?
Does your trailer have it's own batteries, solar, and fans to serve the horses?
Camper Jeff and Kelli's Blog!
A CLOSED MOUTH GATHERS NO FEET!
Buzzcut1
Norcal
Posted: 05/10/15 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Roy Ken
Hand nut is just a rattle tensioner. that bar can only go out through the bottom after you remove the lock at the top ( big L bend underneath.
This is just a measure to foil the quick stop and grab while we are in the TC and not running the generator. Otherwise it lives locked up inside the rig.
RoyB
King George, VA
Posted: 05/10/15 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
one thing for sure is that it seems TORKLIFT has really thought out alot of everyone fears about battery cases and other thief proof things etc...
As much as those Honda units cost you it would just scare me to death almost leaving mine with the trailer when I was away. I have even carried my Honda into a motel room a few times afraid to leave things in my truck parked out side haha...
We do what we do I reckon....
Roy Ken
trailgranny50
North Central Oklahoma
Posted: 05/10/15 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
We went the expense and bought a Lock Down pro for our Honda. It double bolts, a tray to the cargo tray, locked in the receiver hitch, another tray bolts to the feet of the Honda then slides into the base and locks with the huge round Master Lock that sits inside of a welded tray. The thing isn't going anywhere the truck isn't, unless they come equiped with a cutting torch and that might be a bit obvious day or night. Anyway, that's our best option and we no longer need to bring it inside.
2004 Chevy 3500 Duramax all stock
1990 950 Shadow Cruiser Hard side multiple add-ons
Ancient Valco 10'x5' John boat
2011 Toyota FJ Cruiser Trail Team
One-eyed Trail Horse and one horse trailer
Rocky, Annie, Muffie traveling Fur Babies
Buzzcut1
Norcal
Posted: 05/10/15 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
my buddy the welder looked at the powdercoating and decided that grinding and welding would be a royal pain so we swapped out to non nylock nuts and welded the nuts to the bolts
69 Avion
Phoenix, Arizona
Posted: 05/10/15 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Those aren't coming off easily. LOL
Torklift builds real good quality products. Let us know how you like it after you use it awhile.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
