Open Roads Forum
Print  |  Close
Topic: Valve Stem / TPMS 101 Questions
Posted By: paullac on 06/02/15 07:26am
I've had past problems with leaking valve extenders. Basically a trip interruption each of the last 2 years now. We are taking a 2 + week trip this year so want to try to minimize the risks as much as possible. Here's what I want to do. Am I missing anything?
- Replace the existing valve stem / aftermarket extender combination with an all in one system like Tire Man or Dually Valves. I figure going to an all in one system will take away at least some chance for leaks. Plus, I believe I need an all metal system for TPMS. That said, does anybody have contact info for Tire Man as I can't get their website to open?
- Possibly add a TPMS system as well. TST507 seems pretty well liked on RV forums. There's also the one below on Amazon that is rated a little higher & is a little cheaper as well.
http://www.amazon.com/Flow-Through-Senso........8&qid=1433251021&sr=8-3&keywords=rv+tpms
Does anyone have any thoughts or suggestions before I go down this road?
Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
Posted By: Bobbo on 06/02/15 08:04am
Here is the tire man link:
http://tire-man.iwvisp.com/products.html
I have these valve stems on my RV, and like them. Kit #2-6F was the one that fit my tires.
I do recommend a TPMS. I have one. I got it after getting back from driving over 1,000 miles to find an inside rear dually completely flat. I can't rate the TPMS in your link as that is not the one I have.
Bobbo and Lin
Posted By: MobileBasset on 06/02/15 08:15am
Something I learned while searching for a valve installer. Check your local commercial trucking tire dealers. They may be able to provide you with the similar custom brass valve extenders for 1/4 the price of those Tire Man sets. Mine did.
MobileBasset
2014 Itasca Spirit 25B on Chevy Express 3500 chassis
Daisy and Hank the Basset Hounds
Posted By: paullac on 06/02/15 03:17pm
Thanks for the replies.
I called a local commercial truck tire dealer & he wasn't that familiar with what I was trying to do. I think he's more semi focused than class C motorhomes.
I am probably going to go the Tire-Man route (kit 5-6-F which is $167 shipped). Then go to Tire Discounters to have them installed ($24.95 per wheel).
Follow up question: Assuming I still add the TPMS, can I myself simply screw those onto the Tire-Man valves? Or is there something else needed?
Thanks!
Posted By: WesternHorizon on 06/02/15 05:44pm
I like TireTrakers which saved a friend from a serious problem. See details in this post:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27901642.cfm
Yes, just unscrew the silver "fill-through" caps that TireMan provides and screw the TPMS units on.
Here is a picture showing the TireMan extenders, the two TireTraker sender units, and the TireTraker display:
**NOTE / UPDATE** The rubber grommet is supposed to be installed on the wheel itself, not the wheel simulator as shown in this photo.
The labels mean left inside and left outside, to avoid getting them mixed up.
* This post was last edited 06/23/15 10:38am by WesternHorizon *
Posted By: Bordercollie on 06/02/15 10:58pm
I have long solid brass custom formed valve stems installed on our new rig in 2003 and have never had any appreciable air loss. Not sure if I need TMPS system but it would be nice to have digital read outs instead of checking with a tire gage.
Posted By: sfischer on 06/07/15 09:40pm
How does that "checking with a tire gauge" help you rolling down the road when an air leak occurs?
GoneByRV Travel Blog
Currently:
2010 Tiffin Phaeton 40QTH Powerglide Chassis
Current Toad: 2012 Honda Fit Sport, M/T
Prior:
2004 Arctic Fox 29 5-E 5er
1994 Chev 2500HD, 7.4L, 4.10
1994 Jayco 3250RLR 5er
1992 Terry 27' TT
1991 Terry 19' TT
Posted By: Bordercollie on 06/08/15 08:13am
Good point! Can TMPS tell you if a stuck brake caliper is causing a rise in wheel/tire temperature?
Posted By: paullac on 06/08/15 08:22am
OP here with an update. I ordered and received the Tire Man valve stems. I have an appt to get them installed this weekend. Hoping now that the tire shop knows HOW (correctly) to install them. The instructions are pretty detailed. And the guy who I talked to at Tire Man said make sure they do this, and this, etc. I now need to pick up a TPMS to put on once the new valve stems are on.
Posted By: IAMICHABOD on 06/08/15 08:30am
Yes according to their How it works sheet
"TireTraker™ TT400C tire pressure sensor sends a signal to the monitor detecting a difference in tire pressure from the baseline pressure, or an increase in tire temperature above 167° F, both a visual and an audible signal are transmitted. With a flashing tire position light, an audible beep, as well as the flashing tire pressure and temperature icons, the operator knows which tire is in need of attention.
Former El Monte RV Rental
Buying A Rental Class C
Posted By: paullac on 06/08/15 09:33pm
WesternHorizon - OP here. I wanted to comment on your picture. I received my Tire Man kit over the weekend, was reading the instructions, & it says to put the black rubber grommet (not sure the actual term) on the wheel itself. I noticed yours is on the hubcap instead (down in the lower right of the picture). Just an FYI.
Posted By: WesternHorizon on 06/23/15 10:36am
@it says to put the black rubber grommet (not sure the actual term) on the wheel itself
Thanks. I checked the instructions and you are correct. I will add a note to the photo.
Print  |  Close
