RV.Net Open Roads Forum: Soft Flooring in Gulfstream Super C
 > Soft Flooring in Gulfstream Super C
Portable Paradise
Posted: 06/13/15 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Anyone have any experience with repair of a soft flooring in Gulfstream Endura 6430 Super C? I have a small soft spot outside the bathroom.
I get the general gist of the repair but am looking for advise from someone who has done the job. Where are the supports located in this coach? Any type of sealants, glues materials used for a better quality repair.
Thanks Much.
Portable Paradise (down for the moment)
ronfisherman
SE Michigan
Posted: 06/13/15 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Supports for the flooring are built up from frame. The used 1" square. When construction was started. Frame for flooring and compartments were welded in place. Then flooring was installed. Next internal walls and cabinets were installed. Then they install the outer walls. Last was the roof.
If the soft spot is under a wall. Then it complicates the repair. Hopefully yours is not across rooms.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
brothedj14
Ohio
Posted: 10/20/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Good morning. I have a 6340 with the same soft spot. I know it has been a while that you posted this question. I saw the one reply but am interested what you found once you started the work. Thanks for you time. I hope to hear from you. Doug
ronfisherman
SE Michigan
Posted: 10/21/21 04:15am Link  |  Quote  |  Print  |  Notify Moderator
. I made a 1" square tubing frame to support floor on my 6340. Here is a link to a post on it.
Please ask more questions if you need more help.
* This post was edited 10/21/21 04:06pm by ronfisherman *
brothedj14
Ohio
Posted: 10/22/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, good information and pictures.
