RV.Net Open Roads Forum: Class C Motorhomes: best caulking for around windows
 > best caulking for around windows
midnightsadie
ohio
Posted: 06/14/15 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
ok, got a leak but don,t want just any caulk, best one to use? and does it come in colors? where to buy? thanks , and I,ll clean the old off and do a good job.
quingus
Antioch
Posted: 06/14/15 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I think most folks and myself use dicor. Comes in white and clear. There is self leveling for horizontal surfaces and the is for vertical non self leveling. I'm sure the pro's and vets will chime in with more info. Hope I helped. Cheers.
AJR
Close to Madison Wisconsin
Posted: 06/14/15 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Local RV repair place uses Sikaflex. Have it on my front window and have read good reviews.
2014 Leprechaun 290QB Chevy 6.0
2015 GMC Terrain AWD
beetlebug78
Eagan, MN 55121
Posted: 06/24/15 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I use quad available at Home Depot. Just do not use a silicone based caulk
klutchdust
Orange, California
Posted: 06/25/15 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I have used sikaflex in industrial applications, sea going cargo containers to be specific, the grey color. If you get it on your hands it will take forever to come off. It seals and stays sealed but
it does not clean up easy at all.
AJR
Posted: 06/25/15 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Sikaflex makes white and clear boat versions that have very good reviews. They also make a white RV tube that I have used and cleanup is just a tad more messy than other RV stuff I have used in the past. It does take 24 hours to set up. The magic finger coated with soapy water works just fine. It is a bit more “stringy” is ya know what I mean.
