RV.Net Open Roads Forum: Travel Trailers: How to remove oxidation before waxing?
 > How to remove oxidation before waxing?
Griz14
BREMERTON, WA
Posted: 07/09/15 10:10am Link  |  Quote  |  Print  |  Notify Moderator
I bought a used trailer that has been kept outside and I would like to cleanup the fiberglass walls before storing it in my carport. What is the best way to do that?
Thanks,
Griz14
Vulcan Rider
North Central Florida
Posted: 07/09/15 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for posting this specific question.
I make this reply so that I will be tagged on subsequent replies.
Mark Heisler
Alberta Canada
Posted: 07/09/15 11:08am Link  |  Quote  |  Print  |  Notify Moderator
wash your trailer with awesome(this will make it easier to deoxidation)
meguiars power cut compound #M91(for deoxidation)(orange pad)
nu-finsh(white pad)after the first app I put a second one on 2-3 week after
I use a portal cable DA polisher with lake country pads
my trailer will shine for about a year
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
goducks10
There
Posted: 07/09/15 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
I've used Presta Gel Coat compound with a wool pad and a DA sander/polisher. Followed that with 3M Finesse-It 2 Finishing Material using a foam pad and DA.
Last step was Collinite No.845 with a foam pad and DA.
Came out beautiful. Problem is my front caps gel coat is defective as is a lot of darker caps built in the last couple years and all that work quickly disappeared weeks latter. Hey, it was fun while it lasted.
Being that yours is older the gel coat should be fine as far as bringing the shine back and lasting.
gbopp
The Keystone State
Posted: 07/09/15 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Have you ever heard of the Zep/Red Max Pro Application Process?
It works great on older fiberglass.
If you don't want to use the floor polish, just use the wax of your choice after cleaning the fiberglass.
Don't forget the before and after pictures. [emoticon]
DutchmenSport
Indiana
Posted: 07/09/15 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Try spraying a small spot with WD40. Wait a minute and wipe with a soft cloth. See if that works.
It works wonderful for road tar, tree sap, and black streaks!
Vulcan Rider
Posted: 07/09/15 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
That's an interesting idea and I have used it on normal hard, glossy automotive finishes because you can then remove the residue of the WD with a good washing.
I'd be a little concerned that the WD would soak into the pores of the fiberglass and make it next to impossible to get it all OFF and then difficult to impossible to get any wax product to stick good.
My Roadtrek
Tucson, AZ.
Posted: 07/09/15 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Protect All Fiberglass Oxidation Remover, and Color Restorer.
Protect All
Has always worked well for me.
Walmart has it in store, or Amazon.
westend
Shorewood, MN
Posted: 07/09/15 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Any treatment with phosphoric acid based products or TriSodiumPhosphate will remove oxidation. I've been using Jasco TSP substitute for years. I mainly use it on painted surfaces before painting as it removes all oxidation.
If you want a gloss shine, you will then have to buff on a sealer like marine wax or you can straight buff it with cutting compounds but that isn't for the faint of heart (many hours).
I really like Zep products (was using one today for work) but I don't think I'd use the floor wax on my RV. I just think there's risk for yellowing or cracking/chipping and a marine wax is easier to apply and maintain.
I recently got some Parfe liquid wax but have only used it on lawn equipment. From those experiments, I'd say it's a pretty good wax, very durable and the application can't get any easier. After I get done with some other projects, the Parfe is going on the Hilton.
Good luck with your rig. A good coat of wax always says a lot for the owner, IMO.
'03 F-250 4x4 CC
RSD559
Northern Utah
Posted: 07/09/15 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
With our old fiberglass trailer, the problem wasn't oxidation, but it was that the gelcoat layer had lost it's gloss. That was one of the reasons we got rid of it. The decals were peeling and the gelcoat was almost crumbly.
2020 Torque T314 Toy Hauler Travel Trailer- 38' tip to tip.
2015 F-350 6.7L Diesel, SRW.
2021 Can Am Defender 6 seater. Barely fits in the toy hauler!
