RV.Net Open Roads Forum: Travel Trailers: How to remove oxidation before waxing?
 > How to remove oxidation before waxing?
gmw photos
midwest
Posted: 07/11/15 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
westend wrote:
All of this talk of buffing is great until a guy gets hooked on polishing bare metal. I've polished aluminum plate to mirror finishes using average car products and sundry sanders. I use a 10" or 7" rotary to burnish car waxes. As was said, the machine can make movements 1000/1 over hand.
Metal polishing example:
Yes, it's amazing what can be done to aluminum with Mother's brand mag and aluminum polish and some time and effort.
blacktop
pennsylvania
Posted: 07/11/15 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Starbrite.
d1h
Indiana
Posted: 10/27/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
NamMedevac 70
Reno
Posted: 10/27/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
For many years I have had good results using ZEP liquid wash and shine on TT. Removes the white powder residue and leaves a clean shinning finish to the TT. Easy and quick to use with sponge mop and no mess to deal with. Then you can wax over it if so desired. Cheers to the brave
Gjac
Milford, CT
Posted: 10/27/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
The best way depends on a lot of variables. I don't know how anyone can recommend anything without knowing the details. How old is the MH and how bad is the oxidation? Will it come off with just hand polishing with a good compound wax after cleaning it good with the ZEP's process? If so you have your answer. If it won't clean up by hand how good are your shoulders? If good I would use a polishing wheel and a good compound. I have done this before I tore both shoulders on a really oxidized boat and it came out good with white FG and gel coat. Gel coat thickness on a boat hull will be similar to a front and rear cap on a MH .020-.040 ins. Side walls will be thinner. Does your trailer have full body paint? If so it should not be that oxidized and I would be real careful with a machine polisher using the smallest grit possible. My MH is 25 years old and I have two torn shoulders so when I could no longer hand polish about 10 years ago I did the Zeps process and every several years I reapply mostly to the front cap because it gets more wear than the side caps. I have never stripped it I just clean and reapply. My gel coat was really worn so it adhered well and has never yellowed. Still shines better than when I got it in 2004. Good luck with you project, hope this helps.
hondapro
Central Pa
Posted: 10/30/21 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I use Collinite products. All of there products I have tried have worked great. I would first use the 920 cleaner and then the 925
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
