NWboondocker
Hillsboro, OR
Nice ideas, thanks for sharing.
Since you're concerned with battery life, a few simple things:
1) Upgrade to LED lights if not already. After trying a few different styles in my 26QB, I really like this one. A bit brighter than incandescent, still warm, and 1/10 the power.
2) Much more efficient to connect your TV direct to 12v instead of running off converter, if possible. Did Coachmen not install a 12v TV, or did you upgrade it?
'13 Coachmen Freelander 26QB
rockfishon
MD
NWboondocker wrote: Nice ideas, thanks for sharing.
The 2016 21QB has LED's as a standard feature. The TV is 110 only. My main reason for the battery upgrade was to run my coffee maker in the morning without starting the generator at 6am.
rockfishon
MD
16. Added a LED light and switch to the storage compartment.
![[image]](http://i68.photobucket.com/albums/i34/rockfishon/IMG_0841.jpg)
rockfishon
MD
Added a Wide Angle Rear Window Lens so that it is easier to see what is behind me.
![[image]](http://i68.photobucket.com/albums/i34/rockfishon/IMG_20160312_155658.jpg)
Trimmed the seat hatch covers to allow for the table to be mounted further towards the side window. The small pole normally used with the table as a bed is placed in the back hole.
![[image]](https://i68.photobucket.com/albums/i34/rockfishon/IMG_20190818_102936.jpg)
last
edited 08/23/19 06:21am by rockfishon *
View edit history
tred0956
Shuswap, BC, Canada
On my 2008 21QB, the cupboard under the sink was all but useless. By slightly moving the sink drain and P-trap, I was able to build four full extension drawers. The bottom one is high enough for pots and pans and the other 3 are about 4 inches high. We now have lots of room for cutlery and everything else.
We took half the closet and put in shelves and made a pantry.
I built a sliding mechanism for the table so we can slide it towards the outside wall when there is only the 2 of us to give more interior space in the kitchen area.
Repalaced the mattress with a residential style mattress in RV size(75 inches vs 80). Much more comfortable and the shorter size allows it to slide back and forth a bit so bed is much easier to make up.
Added a back up camera, Rear View Safety from Costco, love it.
On the 2008 model, the shower hose comes from the bathroom sink faucet. I moved that faucet to the bathtub, where it belongs (bit tricky with the plumbing) and bought a new sink faucet.
Project for this spring: we have a Thule platform rack that is great for 2 bikes, but there is lots of room between the rack and the back of the MH over the bumper, so I bought a couple of roof mount bike racks and will built a mount on the bumper for them so we can bring both our road and mountain bikes with us.
Wish I could include photos, but we are at our winter home (skiing is GREAT this year) and MH is at summer home.
rockfishon
MD
tred0956 wrote: On my 2008 21QB, the cupboard under the sink was all but useless. By slightly moving the sink drain and P-trap, I was able to build four full extension drawers. The bottom one is high enough for pots and pans and the other 3 are about 4 inches high. We now have lots of room for cutlery and everything else.
I would love to see some picture when you get around to it. Thanks for the additional great ideas.
pconroy328
Colorado
Great minds think alike! We have a 2008 21QB too. I took the left half of the wardroom and slid in shelves on a removable frame. The right side is four full extension drawers also in a removable frame. I figured a future owner might want their closet space back so that's why I made everything revertable-back-to-factory.
The side of the frame is pegboard. Towels and toiletries on the left, foodstuffs and pantry items in the drawers. Larger pans on the pegboard.
For the massive storage underneath, another frame that sits so that it doesn't obstruct the compartments. Then shelving for camping chairs and gear. More pegboard to hold hoses, dump stuff. elec cords etc.
All of this got started when we got the RV and noticed that our previous owner had installed shelving in the basement and decided to screw directly into the freshwater tank!!!
rockfishon
MD
I just added a spray port to the side with a shut off valve next to the propane tank. It looks and works great.
Pic of spray port
Gjac
Milford, CT
Now that you owned the MH for a while now are you still satisfied with it or would you get another? Also have you ever weighed the MH front and back to see how the weight is distributed? I like your model especially large rear storage bay and the 50 gals of FW.
coolmom42
Middle Tennessee
mlts22 wrote: rockfishon wrote: 2: Added second house battery and switch.
Feel dumb by asking, but did you add a second battery, or a second battery bank?
Regardless, I like your switch, and the only thing I'd probably add to that would be a 200 amp catastrophic fuse just so the batteries are protected against a dead short.
I was just reading through this thread and found your mention of this fuse. THAT'S what the one under my hood is! (On the side of the engine compartment, between the chassis battery and something else, which I now think is the house battery.)
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
