RV.Net Open Roads Forum: Travel Trailers: DIY generator box for a honda 3000
 > DIY generator box for a honda 3000
Houston Remodeler
Houston
Posted: 04/22/16 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Temperature readings on an 85 degree day
Click here
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
proxim2020
Houston
Posted: 04/26/16 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I had an opportunity to take some temperature readings. I took the temps after the generator had ran for a couple of hours. We had a pretty good load on it the entire time. We had the 15k AC going along with the TV and the converter charging the battery. I used a wireless indoor - outdoor thermometer to take the temps and all are internal.
Outdoor Ambient: 85 degrees
Location #1 - 97 Degrees: This is the location in front of the left fan. Also where my kill switch is located.
Location #2 - 110 Degrees: This is the location in front of the fan on the right. The exhaust blows into this fan.
Location #3 - 86 Degrees: This is the air intake side of the generator.
Location #4 - 89 Degrees: This is the temp on top of the gas tank.
Here are a few pictures of the box.
Houston Remodeler
Houston
Posted: 04/26/16 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Thanks ! since my readings were higher, I'll keep an eye on the temps.
Really appreciate your effort.
Houston Remodeler
Houston
Posted: 05/09/16 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
We had a chance to use the generator in the box for an overnight boondocking stay. It purred along, barely audible, for 17 hours using half a tank of fuel.
azrving
Oatman
Posted: 05/09/16 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Nice job. I agree with the idea of being as quiet as possible with our generators. I built a 12 gauge steel cabinet with a similar 120 v fan and vent. I also made the cord long enough that I can park the back of the truck away from our rig. Only problem is forgetting to shut it off. At times, depending on where we are I will keep the lid propped about 2/3 of the way open.
samhain7
Toronto
Posted: 05/09/16 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
Proxim2020. Where did you get the fans?
Final notice from MasterCard. Good! I'm sick of hearing from them.
2014 Dodge Ram 2500 6.4 HEMI, 3.72, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
proxim2020
Houston
Posted: 05/10/16 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I got them from eBay. I got the pair from a seller named Speed Daddy, but there's lots of people that sell the same fans. They come in sizes from 6" to 16". According to the info online each one of my 12" fans push out 1700+ CFM.
http://stores.ebay.com/Speed-Daddy-Com/C........018&_sid=841766438&_trksid=p4634.c0.m322
Houston Remodeler
Houston
Posted: 06/05/16 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Spent several days driving through Arizona in 110ºF heat, the generator powering the air conditioning in the TT as we rolled along. No problems.
rickv3
ontario
Posted: 09/07/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Houston Remodeler, just found you're post today, have the same honda generator, wondering how the box is functioning, is the generator staying cool or overheating, this is a great design and would like to make one for my generator, how do you open the picture image in the instruction how to construct. Thanks in advance
Rickv3
____________________________________________
2014 jayco eagle 5th wheel 27.5 rlts
2008 ford lariat 450 dually
Houston Remodeler
Houston
Posted: 09/20/20 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
We've been running the exact same box since the original post. We used it Labor day weekend at the beach. Still going strong
