RV.Net Open Roads Forum: What jack to lift one corner of a Class C E450?
 > What jack to lift one corner of a Class C E450?
bzboy
Colorado Springs
Posted: 05/16/16 09:43am Link  |  Quote  |  Print  |  Notify Moderator
crasster wrote:
Bottle jack. Get several chunks of scrap lumber too for stacking. Also while we are talking, a LONG breaker bar if this is for tire changing.
How long of a breaker bar do you recommend? They got anywhere from 24 to 40 inches available.
pnichols
The Other California
Posted: 05/16/16 10:21am Link  |  Quote  |  Print  |  Notify Moderator
j-d wrote:
The Low Profile 12- and 20-ton are intriguing. Question is do you want to pick up from low, or to be able to lift a little higher (low profile vs. standard)? I have seen double-extending bottle jacks, where they were really squatty but got good height because they had a telescoping ram, a piston within a piston. These low profile HF jacks are NOT that type.
Here's the double-ram (for added lift height) low profile 12-ton jack I carry in our Class C:
http://www.site.torinjacksusa.com/bigred......../item/12-ton-dual-stage-bottle-jack.html
To me, the ultimate would be a double-ram low profile 12-ton jack that was air lift with a 4 foot or longer air hose that DID NOT require a compressor - but instead had a levered hand pump at the end of the air hose. This ultimate setup would be the best of all worlds for lifting a Class C: HIgh lift, low profile, 12-ton lifting weight over-kill for long term reliability, air lift via a long hose for operator safety ... with the air pressure not requiring a compressor or air tank for simplicity and minimum storage space.
* This post was edited 05/16/16 01:07pm by pnichols *
2005 E450 Itasca 24V Class C
Btosuner
Peoria, Arizona
Posted: 04/11/23 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
thank you
Posted: 04/11/23 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Baja Man wrote:
Would like to get a jack to keep on board my 31' Class C, as well as any time needed at home.....to lift one corner at a time.
I have 6 ton jack stands to use once lifted.
Any tips on jack placement on chassis, storage, tire removal, etc.
Thanks!
Wondering if this would be good for on board as well as home use...
Harbor Freight Jack
I don’t even trust shop towels from Hazard Fraught, but to each their own. I’m sure it’s fine.
Do you have onboard air to use that jack with?
WinMinnie02
NJ
Posted: 05/15/23 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
3 ton floor jack 1 wheel at a time is fine. 6 ton jack stands, impact wrench, breaker bar, impact sockets.
30sweeds
Iowa
Posted: 05/19/23 05:43am Link  |  Quote  |  Print  |  Notify Moderator
There can be problems with almost any jack if you happen to have a flat on the front.A bottle jack won't get under it where you need to be to get the tire off the ground...and more problems if not on concrete.Black top not usually good enough.I built a 6 inch high wedge out of 1 inch plywood to run the wheel up on to get the bottle jack under it and if not on concrete,something relatively thin and extremely sturdy for under the jack to keep it from sinking in the ground.These things are HEAVY! Just went through this.Wished I would have called AAA.
Valpo Camper
Valpo, Indiana
Posted: 05/24/23 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the old thread posting. So what weight limit jackstand would be best for the front of a class C? I need to jack up the front to look at my front brakes. I have a 10 ton bottle to lift it just not sure how much hold capacity I need to support it. I have car stands on hand that will hold 2 tons each so if I can lift it then set both on the side I am working on then I should be able to support 4 tons.
2005 Gulfstream Conquest LE 28 foot
2001 Grand Cherokee, 4WD station wagon
2006 Saturn Vue, AWD V6
"For those who fight for it, life has a special flavor the protected will never know." --Unknown defender of Khe Sanh in Vietnam
Posted: 05/24/23 09:03am Link  |  Quote  |  Print  |  Notify Moderator
If you think you can set 2 jack stands side by side and leave the other front wheel on the ground, you may have failed pre school and the square block round hole test.
I’d suggest staying away from things that may injure you.
PS it’s ok to bring the thread back up. It was a weird one anyway….always fun when Baja Man posts!
Valpo Camper
Valpo, Indiana
Posted: 05/25/23 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Well I did not fail the round peg game but I have not honestly looked at the front end if I can get 2 stands side by side. Like I said I want to do the front brakes but I also don’t want to pay for something I can do myself. I can support 4 tons with jacks I have on hand if they will fit or if I can do it with 1 stand then maybe that is the way I will go.
