RV.Net Open Roads Forum: Onan generator Carb cleaning, no need to replace carb.
 > Onan generator Carb cleaning, no need to replace carb.
RV Hero
Home lakeland
Posted: 07/02/16 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
putting a T in the line feeding the carb, then I can hook a hose to it with carburetor cleaner , coming from a bottle held higher then the generator. This way I can put a concentration of carb cleaner directly into the bowl...run for a minute shut off and let it sit for 30 minutes so it removes all the gum and gunk from inside the carb.bowl, then restart,,, when done reattach gas line...what do you think...this would saved over $700 cost to replace carb.....This cure would save everyone with these generators a lot of money.....Call me RV Hero......one note I used Sta-bil treatment in my gasoline. research that fuel is pumping has shown me that it is in the carb. a little cleaner in the gas line makes it start and run for a few minutes. needs a bigger dose.
Day 2,,, I did the concentration trick filling the carb and running it on B12 and seafoam, let it soak about 20 minutes ran it and did this 5 times,,,then filled it again let carb take only the mixture...out of a plastic peanut butter jar... then let it soak for 5 hours....then started again,,reattached gas line and put everything back to normal...it runs but rough idle...I need to choke it to start it...now I am going with the gas filter and fuel pump switch...maybe not enough gas..when I checked the gas flow before I started it pumped but small stream.....I do believe the inside of the carb is clean...from all the carb cleaners...does anyone know how much gas should pump? Thanks
* This post was last edited 07/04/16 05:16pm by RV Hero *   View edit history
romore
Okanagan valley British Columbia
Posted: 07/02/16 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
It likely won't restart, any mung loosened will clog the jets. There is really no need to replace a carb that isn't severely worn, damaged or corroded and no amount of cleaning will cure that. Careful disassembly and cleaning should solve most problems, just hope you don't need a kit as Onan is very proud of those too.
gbopp
The Keystone State
Posted: 07/02/16 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I thought that's what most people do when using Seafoam to clean the generator carb. It seems like common sense.
Or, maybe it's just as easy to remove the fuel line and attach the cleaner line.
Maybe I'm missing something?
j-d
Sunny Florida USA
Posted: 07/02/16 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
You've made an A-Dapter that makes it much easier to do what has worked for several of us: Remove Fuel line to Carb. Pour the cleaner into Line. Start genset and shut down to let it soak. Be sure to use fittings that won't leak while you aren't carb cleaning. A similar trick is to dose a gallon of gas heavily with cleaner (many like Berryman) and fuel the genset with that mixture.
If you have an ONAN 4KY genset, those carbs have tiny passages that are laid out so you can't "tag wire" them for cleaning. So... If you've got a fix and it works, Good On You.
I met a sport fisherman named Joe from North Carolina. He'd drive his Class C to FL several times a year to fish. One day he was running his generator and I commented how well it started and how smooth it ran. Joe said he puts StaBil in every drop of gas that goes in that 55 gallon tank on the E450. Even on those 700 mile road trips, I asked. And Joe said Yes, Every Drop. So now, j-d does like Joe. I had to replace a carb a few years ago and I don't want the trouble or expense again. Been good now for several years. I still exercise the genset, but now it always starts, always runs well. Just like Joe.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
Sam Spade
North Central Florida
Posted: 07/02/16 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
If you practice a little good preventive maintenance......and use a good carb cleaner like Berrymans B12 Chemtool or Gumout.....instead of an over-priced fuel stabilizer marketed as a cleaner, like Seafoam, simply putting the required amount IN the gas should keep you running fine.
Seafoam really isn't good if you neglect things until there is a severe problem. B12 is about as good as it gets but in really severe cases even manual cleaning can't get to the tiny passages that get blocked with what sometimes resembles concrete.
$700 seems WAY too high for a simple carb replacement.
Look for some different Cummins dealers.
F1bNorm
Gardena, CA
Posted: 07/02/16 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
It amazes me how well SeaFoam works. I wait until my MH fuel tank is down to its last third of a tank (enough that I know the gen can draw fuel) and dump in a can of SF. It works great on my little Honda stuff, too.
I did learn from the Honda techs, the best fix for occasional use, is to drain the carb bowl before storage. I wish the Onan had a drain.
Norm
F1BNorm
gbopp
The Keystone State
Posted: 07/02/16 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I actually wanted to say, Seafoam or the cleaner of your choice. Obviously, I didn't. [emoticon]
I have not tried Berrymans yet. But I will. Thanks.
edatlanta
Maplesville, AL Home Base
Posted: 07/03/16 04:29am Link  |  Quote  |  Print  |  Notify Moderator
I use StaBil Marine formula in every drop of gas that goes into my Onan and only use ethanol gas if it is the only gas available. If I have had to use ethanol gas I ALWAYS run the tank dry and fill with non-ethanol gas. I run it on the first of every month for an hour under load and NEVER fail to do this. It has 352 hours on it now and has never failed to run and provide electricity when I need it.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Sam Spade
Posted: 07/03/16 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Given your good practices with the fuel, I think your obsession over not using ethanol is a gross over-reaction.
Ethanol is NOT the work of the devil.
Some areas of the world have been using E90-E100 for decades.
klutchdust
Orange, California
Posted: 07/03/16 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Sta-bil goes in all my vehicles and each fuel can that is used for small engines and haven't had a problem. I use Marvel mystery oil in my diesels along with a fuel lubricity product due to the low sulphur content in today's diesel fuel. I have used sea foam, best price is walmart, and after using it the rough idle in my Jeep stopped, the 85 mercedes diesel idles better and daughters stalling Suburban doesn't stall anymore when turning on the air conditioner, you decide.
After reading Sam Spade's comments i researched Berrymans and Seafoams MSDS sheets and I was quite surprised with the difference in ingredients. I have always
had a good response with sea foam but I think my choice for my gasoline engines has changed.
* This post was edited 07/04/16 08:35am by klutchdust *
