RV.Net Open Roads Forum: Fed up with RV covers Wearing Out!
 > Fed up with RV covers Wearing Out!
Padlin
W. Ma.
Posted: 09/02/16 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Had the better (white Tyvek top), lasted 6 years. By mistake I ordered the cheap ADCO to replace it, lasted just under 2 years.
Trying a Calmark this time, bulkie and heavy to haul up on the trailer, but it looks like it'll last forever.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
smcrea
California
Posted: 09/02/16 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that the hard cover type is best but we store our trailer in a storage area so this is not possible
Any other suggestions?
Thanks!
waterboy502000
Cottonwood, AZ
Posted: 03/06/17 10:19am Link  |  Quote  |  Print  |  Notify Moderator
ICamel wrote:
Calmark Cover Company. The best!
Yea, if you want to spend 2 grand.
2012 Winnebago Chalet 31CR, E-450 Super Duty, 1994 Tracker, Sterling All Terrain, 160 watts solar w/Blue Sky controller, Winegard G2.
NYCgrrl
Posted: 03/06/17 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I'd get a UVA/UVB rated textile and drape the RV in it then weigh it down.
Prolly would be good at keeping dust and possibly rodents out of the unit as well.
Should you want it custom fitted I'm sure a marina shop could help.
colliehauler
Mc Pherson KS USA
Posted: 03/06/17 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
bukhrn wrote:
Hondavalk wrote:
Not trying to be snarky but it is the best, easiest solution.
X-3, only mine is a little bigger, 20x40, and closed on 3 sides.
X-4 a lot easier then messing with a cover especially in the wind.
DickOK
Tucson Arizona
Posted: 03/06/17 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
We live in Tucson. We have had an Adco sunbrella fabric cover for 6 years. Still like new.
Dick OK
RGar974417
Robesonia,Pa 19551
Posted: 03/07/17 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
We have tried 3 different covers. Each lasted about 3 years.But the thing I really didn't like about them was they let the water through and when you took them off the RV was really dirty. So for the past several years we used plastic tarps. We have a 26ft TT so I bought a 30 x 20 tarp. It was about $60. I then bought some 2" straps that go completely over and under the RV. Don't try to keep it on with just the gromets although you will need to use some to keep the edges from flapping. Anyways we usually get 2 years out of each tarp and the best thing is when you take them off the trailer is still clean.So do the math.Buy one cover that last for 3 years at $350 that lets the dirt in or a tarp that lasts 2 years @ $60 that keeps the dirt out?
colliehauler
Mc Pherson KS USA
Posted: 03/07/17 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought my RV the dealer gave me a information sheet which said not to use a plastic tarp because it can damage the rubber roof from trapped heat.
down home
south
Posted: 03/07/17 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
We had the same problems here in the Southeast with our RV cover. Best available at the time.
I see in ads new cover with panels to let air through instead o billowing in the wind. Every time we had high winds I had to retighten the straps underneath but it was never enough. The material kept stretching or the belts slipped through the buckles. Eventually about the third year the corners on to were gone.
We padded the corners but the corners had all kind of green algae etc on them.
A neighbor had his plastic wall paper slip, in a fairy expensive Fifth wheel and fixtures droop and other problems from heat buildup and moisture. The winds were loaded with moisture and up and under the cover.
The newer ones with the wind panels, or whateever they call them should help a lot The only logical effective solution is a building.
That $400.00 cover or less is not a long term solution and in many cases a problem instead of a solution.
Presents a problem where you live, at least with the picture, I have in mind.
Still the best thing to do is a building with air circulation reduction in inside heat from shielding from sun, and protection from all the elements.
RGar974417
Robesonia,Pa 19551
Posted: 03/08/17 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Well I cover mine in November and take it off in March so I doubt that would be an issue. Plus he probably wants to sell you a cover.
