RV.Net Open Roads Forum: Truck Campers: Anza Borrego TC Rescue
 > Anza Borrego TC Rescue
Page of 5
anutami
Ramona
Posted: 11/14/16 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
buried my camper this weekend in June wash. Pulled into the wash and thought, I don't need to put it in 4wd just yet..
200yards down the road decided to stop for lunch and then put it in 4wd...
It just won't engage!!
I got to dig a swimming pool in the desert
5 hours later I had enough and called my bro who came to the rescue
RESCUE VIDEO
finally got to our campsite for the weekend and could relax
thinking of adding some rescue platforms to the gear list, any suggestions?
also, after 5 hours of my camper being totally out of level, my fridge shut down and took the whole weekend to get back in the 30's, another reason to get a compressor fridge.
* This post was edited 11/14/16 04:31pm by anutami *
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
JoeChiOhki
Sauvie Island, OR
Posted: 11/14/16 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Right sized winch, bury-able anchor, being certain to lock in 4x4 before you leave the pavement [emoticon]. Also, deflators and a compressor so you can drop your tire pressure to help you float out of loose situations like that.
Auto-lock type hubs require the wheels to turn and the rig to travel a bit before they fully lock up.
Oh, and always travel the back country with a second team if possible.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
Tiger4x4RV
Inland Empire, Southern California
Posted: 11/14/16 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I do remember not going all the way up June Wash because of deep sand, therefore having to hike further to the viewpoint at the end.
DRW in low 4 is best for sand. My pre-Tiger had DRW, which mostly I did not like, but I miss it in sand. Tiger is SRW, and low 4 has floated me out of several places.
But hey, at least you got rescued and the camper stayed whole and on the truck this time!
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
the bear II
Torrance CA.
Posted: 11/14/16 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Can't tell if you lowered the pressure on the tires it helps.
Practice makes perfect--- take it out and practice getting stuck and unstuck.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 11/14/16 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Wondering whether you are still relying on the Ford vacuum system of 4 wheel drive. After paying and paying to fix it, I put on some Warn hubs and now it works when I put them in every time.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
anutami
Ramona
Posted: 11/14/16 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
I went down to 40 psi, but the sand was just too deep and my rig too hvy
anutami
Ramona
Posted: 11/14/16 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Nice, will look into that.
Thanks
Buzzcut1
Norcal
Posted: 11/14/16 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Even with the auto lockers you can just twist the dial on the hub from auto to lock for 4wd. I do that whenever the surface looks iffy. Then all the dash switch is doing is engaging the front driveshaft to the transmission.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
kohldad
Goose Creek, SC
Posted: 11/14/16 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Probably could have gone down to 20 psi which would have helped a lot more too. Though without 4wd, any pressure was probably a lost cause.
Did you ever figure out why the 4wd didn't engage?
Last and most important, how pleased are you with the BFG AT K/Os? Are they wearing well with the heavy camper weight?
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Artum Snowbird
Posted: 11/14/16 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Just so you understand... With the Warn Hubs you have to get out and manually engage each hub, and then remember to take them off engaged when you are done. But, having said that, when you put the dash switch into low range, you now have a terrific low range rear axle by itself. I use mine that way to climb up on blocks and often do not have to actually engage the front wheels to climb up. The seals in the Ford hubs fail over and over again.
Page of 5
