RV.Net Open Roads Forum: Tow Vehicles: Battery Tenders
Search only in Tow Vehicles
 > Battery Tenders
RCMAN46
NorthWest
Posted: 12/11/16 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
One thing you need to know about the battery tenders.
If left connected to the battery with no AC input the tender will run down the battery. The battery tender has a small load on the battery.
I had one on a car and the GFI had tripped. After 5 months the battery was totally dead. I mean like 1.5 volts dead. Not sure when the GFI tripped.
GA1dad
Upstate South Carolina
Posted: 12/11/16 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
How long does your truck sit between uses?
A couple of weeks and it goes down enough to keep it from starting. It'll roll over a few times, then click/click. Seems like I recall the gauge showing around 10 volts when this happens. If I drive it every few days there is no issue. I should just break down and drive it daily, it gets better mileage than my s-10 4x4. But that little 4 door S-10 is a good commuter.
Thanks for the advise folks!!
austingta
Austin TX
Posted: 12/11/16 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
There is something wrong for sure. The ECM and other things that use current don't use very much at all. You may have a battery or alternator problem.
Are there other uses that are left connected?
Frank Brooks Austin TX
2018 F 150 King Ranch max tow package with 3.55 gears
Published towing weight limit 13200
Payload per sticker 1464
dodge guy
Bartlett IL
Posted: 12/11/16 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Newer vehicles have a small draw. small enough so the computers don't draw it down over several days, but enough that if it sits for extended periods it will get drawn down. My X used to get pretty drawn down after 3 weeks, it would start, but crank very slow!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Isaac-1
SW Louisiana
Posted: 12/11/16 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
It all depends on how much you want to spend, I have one of the cheap $20 1.5 amp harbor freight battery tenders on my 30KW diesel home standby generator it has been hooked up for 6 or 7 years and is still working. I change the battery out every 5 years regardless if it needs it, just because I don't want to ever have to deal with a dead battery during a storm. By contrast I have an BatteryMinder model 2012 which sells for $90 on amazon on my old diesel 7.3 F250 pickup (2000 model) which only gets driven occasionally to haul stuff on the weekends, again it works, gives a few more bells and whistles than the $20 Harbor Freight model, I don't know if it really worth an extra $70 though. (I bought it on one of their lightning deal specials a year or two ago for about half off during the holiday season.
(my motorhome has 400 watts worth of solar panels on the roof which keep the batteries charged)
rhagfo
Portland, OR
Posted: 12/11/16 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
That is the best thing you can do for the truck, drive it.
Turtle n Peeps
California
Posted: 12/11/16 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^ This. Somethings up.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Strabo
Hooligan #96 -KampRat -Offroader
Posted: 12/12/16 12:53am Link  |  Quote  |  Print  |  Notify Moderator
I use a solar maintainer for our toyhauler after I fully charge the battery bank. It's important to have a small constant charge on batterys that are not used regularly. Seems to work fine, 3 watt output.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
Chuck_thehammer
Ohio, or Very South Texas
Posted: 12/12/16 06:47am Link  |  Quote  |  Print  |  Notify Moderator
answer is not so easy..
the older the battery . the faster it discharges.
I avoid the cheaper tender types.. Deltron Battery Tender was top. others are catching up.
1.5 amp with 2 batteries.. adding a single 2 amp diode will stop back draw.
over 3 weeks I can see a slow start. but NOT a No start.. if it continues have truck checked..
do you have add-on electronic devices in truck, they may not be turning off.
Snowman9000
IL
Posted: 12/12/16 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Yeah the batteries could simply be old and feeble.
My 2004.5 Duramax has a parasitic draw of 21 mA. Which I think is not much?? I was chasing a battery problem recently. Starting was weak on a good day, and got worse as the truck sat. It turned out to be a corroded + terminal on one battery. Prior to that I had never seen corrosion in a GM style terminal. I cleaned it up and everything has been great since.
2014 Sunseeker 2300 Class C (Chevy 4500)
 > Battery Tenders
