RV.Net Open Roads Forum: Fifth-Wheels: Best wheel bearing grease
 > Best wheel bearing grease
Page of 5
justafordguy
Tallahassee Fl.
Posted: 01/27/17 02:04pm Link  |  Print  |  Notify Moderator
I don't think the problem is the grease they use but the way they put the grease in. They probably use a air/hydraulic grease gun and put the grease in so fast it blows past any seal. If you hand pack them or use a manual grease gun and go slow while turning the hub the grease won't go past the seal.
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
garyp4951
TN
Posted: 01/27/17 08:02pm Link  |  Print  |  Notify Moderator
ScottG wrote:
I avoid all synthetic greases. I've tried all the major brands (Amsoil, Mobile 1, etc) and they all separate and drool oil out of the joints. My mechanic buddy quit using it because of this issue.
Good dino grease will work fine.
I agree, i got tired of red syrup dripping out of my grease gun.
Likes to tow
Huntington WV
Posted: 01/28/17 04:13am Link  |  Print  |  Notify Moderator
As many others have said, to use the zerk and fill the entire hub with grease is just inviting trouble. There is no way for the front bearing to get grease unless the cavity is filled. As the grease gets hot from using the brakes a lot, the grease expands and blows past the seals. Easy lube hubs with the grease fitting are great for boat trailers or on those trailers without brake shoes.
FarrissE
1700 S Charles St, Baltimore, MD 21230, USA
Posted: 12/14/21 08:40am Link  |  Print  |  Notify Moderator
The best RV wheel-bearing grease that I found is Plews & Edelmann LMX. It is really convenient and easy to use. It is soft enough to be applied to bearings. It does not drip easily, so it will linger where it has been applied. In addition, this grease has anti-corrosion properties that help prevent the gradual deterioration of my bearings. This is very convenient because I won't have to think about getting a replacement soon. This grease is insoluble in water, so there are times when my RV wheels are wet due to road conditions during the rainy and winter seasons. I’m always confident that the bearings are well lubricated.
cummins2014
Utah
Posted: 12/14/21 09:02am Link  |  Print  |  Notify Moderator
This thread is pretty old ,the OP asked about Red N Tacky, some seem to be having heartburn with synthetics , I have used both Mobile 1 ,and Red N Tacky ,both have performed well.
Cummins12V98
on the road
Posted: 12/14/21 09:12am Link  |  Print  |  Notify Moderator
Been using AMZ/OIL grease for decades and never have had a bearing go bad.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 12/14/21 09:52am Link  |  Print  |  Notify Moderator
My dad's usual response was "whatever's in the grease gun". :-)
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
fj12ryder
Platte City, MO
Posted: 12/14/21 01:14pm Link  |  Print  |  Notify Moderator
Lyle
Ayup.
Howard and Peggy
"Don't Panic"
garyp4951
TN
Posted: 12/14/21 06:56pm Link  |  Print  |  Notify Moderator
This does not leak out of the grease gun or hub.
ford truck guy
Pennsylvania
Posted: 12/14/21 07:14pm Link  |  Print  |  Notify Moderator
^^^ that is what I use ^^^
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Page of 5
