Cloud Dancer
San Antonio and Livingston TX USA
bobsallyh wrote: Remember those wheels and attachments are made in Germany. You know anything Europe puts out is better than anything made in the good old USA.
Thanks for the tip. I'll get Penski, Gibbs, and Hendrick to call Germany, and order 40 brass and 40 titanium nuts apiece. They can afford to experiment a bit (they get a tax break).
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
bucky
Raleigh metro
Or they could try Dez nuts.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
p220sigman
Tallahassee, FL, USA
Let me preface my question with the fact I don't watch much car racing in general, but I do stop for a few minutes when channel surfing if a race is on.
I ask out of ignorance. Don't F1 cars use a single central nut on their wheels? Why don't they have similar issues with wheels coming off? Are there design differences between the wheels (other than the obvious size/width) that make F1 wheels easier to install/secure?
Cloud Dancer
p220sigman wrote: Let me preface my question with the fact I don't watch much car racing in general, but I do stop for a few minutes when channel surfing if a race is on.
The heat build-up is significantly much higher in NASCAR racecars vs F-1. PLUS, it's much easier to get rid of the heat in F-1 brakes, and wheels.
p220sigman
So the wheel nuts heat up and expand at a greater rate than the spindles so they loosen up? I wasn't sure if it was an issue with the wheels not seating fully before the wheel nut is tightened or a failure of the nut/spindle or something else.
FlatBroke
CO/AZ
Brad keslowski to home a wheel and nut because he felt they had a safety issue and modified it. He got excessive fine. I wonder what they did.
Hitch Hiker
"08" 29.5 FKTG LS
Cloud Dancer
Be aware that what I do is look at the brake energy, vector analysis, thermal dynamics, my years of experience with steel, aluminum, and magnesium wheels (with "knock-off wing or hex single nuts}. THEN, I take a WAG as to what might solve THEIR problem. I believe it's a metal GALLING problem. If you look at all the elements of the problem, what they have is a "perfect storm" for metal galling,.....especially if they overtighten the nut when everything is unevenly hot. AND, if they're using left-hand threads on half of the hubs,...who knows if the impact air gun is set on the proper mode? For all we know they might first erroneously tighten a hot-hot system ,...and THEN attempt to loosen the nut???? I wish I was Penske. I would buy me spanking new $$$90K Ranger bass boat and go fishing. Years, ago when I bought mine, it came with stainless steel engine mounting bolts WITH brass self-lock nuts.
edited 05/20/22 09:22am by Cloud Dancer *
Geo*Boy
Unknown
Why not just go back to what has worked since the start of NASCAR, 5 lug nuts?
bucky
Raleigh metro
Because NASCAR will never admit that they blew it. My question is how did this not come up in testing?
Nascar has never liked Kes because he calls them on the BS.
edited 05/22/22 03:37am by bucky *
Cloud Dancer
NASCAR has made more millionaires out of drivers than any other USA racing organization. IMO smart drivers are careful to measure their words whenever they say anything critical about NASCAR. I'm sure NASCAR will find the solution to the nut problem. (I get to watch for free....)
