RV.Net Open Roads Forum: Class C Motorhomes: Weather cover during storage
 > Weather cover during storage
BillHoughton
West of the Mississippi
Posted: 03/21/17 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
We're storing the RV outside (23 foot Itasca Navion). Our property is such that there's about one spot where I can level the rig, which leaves the front of the RV under a redwood tree. After this last winter's rains, the hood and the front of the roof are stained - I've got some hours of rubbing out ahead of me.
A carport, or even a level pad on which to park it that's not under the tree, are not on the list any time soon; so I'm wondering about a weather cover, and have some questions:
1. From some quick Google shopping, I have the impression that the covers have places where you can access the doors (cab and house); is that right?
2. How in heck do you install a cover on an object 11 feet high and nearly ten feet wide, with various bumps on the roof?
3. Does anyone have a particular brand to recommend?
4. What are the questions I didn't think to ask?
Thanks for help, y'all.
crasster
Dallas
Posted: 03/21/17 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Personally I can't stand RV covers. They are very tough to work with. A job to get on and off... It will definitely require roof access.
With that said, I do believe one of the best things and RV owner should buy BEFORE they buy a coach is a metal building to keep it in. It doesn't need to be fancy or anything. Keep these things out of the elements and they can often last a lifetime. I've even seen tires go 12+ years when stored indoors.
Anyway to answer your question, covers are tough but they do work. You need to make them impeccably tight.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
ctilsie242
Austin
Posted: 03/21/17 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am not a fan of covers. If they have any play, they can flap in the breeze, abrading the surface of the rig. Instead, if one has the ability, get a pole barn or aluminum building... heck, even a ShelterLogic tent garage.
Plus, if you make the garage bigger than the rig, you have additional storage for seasonal items like Buddy heaters.
Johno02
Lexington, TN USA
Posted: 03/21/17 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
When we got our first motor home, I was going to build a garage to keep it in, but my banker said NO. in his opinion there was no need for an expensive garage to shelter a motor home that should not ever be there. His thought, and we agreed, was to use the cost to buy gas, and not need a shelter at home. Keep it out on the road! So we have!
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 wife, 1 dog(?)
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 03/21/17 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Friend of mine bought a named brand cover for his 38 ft 5thw 2 yrs ago. Did not last the summer here in Yuma. Tore all to heck in the wind. Took 4 guys to put cover on the 5th w. They said never again would they have a cover. I have a 40 ft enclosed metal cover for my TT
samsontdog">">
ronfisherman
SE Michigan
Posted: 03/21/17 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have a cover. It's made with Sunbrella. Same as a boat top. Bought it in 2006. Still works well. Thread that was used to sew it together are starting to go bad. But our 13 year old MH looks like new.
Getting cover on can be a problem. I have a tractor with a front end loader to lift the 75 lbs cover to top rear of MH. Then pull the cover toward front of MH. With cover centered on roof start spreading out sides toward edge of roof. Start dropping sides down from front to rear of MH. I work towards MH ladder. Then start climbing down ladder while pulling rear of cover down. When top is in place. Install bungee straps in the 15 sets of grommet holes. This ties cover down so it will not billow or move around when wind blows.
I got my cover from Calmark. It was more than twice what the ADCO and similar covers cost.
Here is a picture of it installed.
http://s35.photobucket.com/user/ronjhall/library/misc
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
Death Valley!
Posted: 03/21/17 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I cover my TT that's about the same size as yours 22 x 7.5 feet plus back bumper and tongue and highest point 10 feet, the AC. With my extension ladder and working slowly I can do it alone without getting on the roof. Yes, I can access my TT's door but can't use the slide. TT two years old and shines like new. Cover lasted two years...just replaced.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
loggenrock
New Hampshire
Posted: 03/21/17 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Coachmen B+ - have used an Adco cover on it past 2 winters without a problem. Key to putting it on is how you take it OFF the previous time! I've found I fold the sides up first, so it is "inside out", if you will, on the roof of the coach. Then roll it, starting from the front. To deploy, just set rolled cover on the roof, unroll over the front, drop the sides down and secure. I can do it alone, either just using the attached roof ladder, or a separate 10' step ladder. For my 25' coach the weight really isn't too bad to handle. And yes, mine has 3 vertical zippers on the curb side, so I can access the front cab door, the side coach door, or even the rear side compartment. As stated earlier, you cannot deploy the slide with the cover on. As far as the A/C, skylights/vents on the roof - it just lays right over them all winter. So far it has done a nice job keeping the rig clean. ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
BillHoughton
Posted: 03/21/17 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of really good information here. Thanks, and keep the ideas coming [emoticon]
samven1
Hedgesville, WV usa
Posted: 03/21/17 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have been considering a cover for mine also. I can park mine in back and its just slightly out of level which is ok with me as it keeps the rain water running off the opposite side of the coach door. But I get the black streaks from run off and I worry about the snow melt finding a way inside. If I could just keep the roof covered so I would not have to worry about leaks I would be happy.
Sam
03 Dodge Ram 1500 QC LB Hemi
2015 Four Winds 22E Chevy
