RV.Net Open Roads Forum: Beginning RVing: auxiliary fuel tank
 > auxiliary fuel tank
schl44
wisconsin
Posted: 04/10/17 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
We have taken two trips with out Fifth wheel. My tow truck is a 2012 F350 with a 6.7 diesel.. Being my factory fuel tank is very small im forced to stop often to refuel which is a pain to me. So I want to buya a auxiliary tank that fits behind the cab and ahead of the fifth wheel hitch. Thinking of at least a 60 gal tank with gravety feed. I have read that some may leak fuel out the vent as fuel sloshes. Any recomendations would be appreciated. Thanks!
MarkTwain
Northern, Ca. , USA
Posted: 04/10/17 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Check with Transfer Flow in Chico Ca. 1-530-893-5209 transfer flow.com. I don't think gravity feed fuel tanks are legal. I had a 60 gal fuel tank installed in the same location my original tank was located.
dmck413
Fluvanna Va
Posted: 04/10/17 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a 40 gallon and LOVE It! Put a solenoid in the fuel line to start flow when you tank is down.
2oldman
Salton Sea
Posted: 04/10/17 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Similar post
..and another
DutchmenSport
Over There
Posted: 04/10/17 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
On another post, forum member Gdetrailer posted this. I was so impressed, I'm am seriously considering getting one. (not for travel), but for my garage to fuel my lawn mowers and such: Click here. Look at the bottom of his post, the picture! Pretty nifty idea!
Bird Freak
Calhoun, Ga.
Posted: 04/10/17 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
tractor Supply sells them everyday. I have installed 2 in 2015 F350's and they work great.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
boogie_4wheel
SLC, Utah
Posted: 04/10/17 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel can be pushed out of the overflow depending on tank design when the tank is filled to the brim. Had 2 trucks with aux tanks and no issue if I left a little air gap in the tank.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
sayoung
Tx
Posted: 04/10/17 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have often thought about adding tank but I need the stop [emoticon]
Nicholsfamily05
Brooklyn
Posted: 04/10/17 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
We added a 50 gallon tank to our tow rig. We purchased it from transfer flow. It's our second one from them. This time we got the trax system with it and it's an awesome system. Controls the pump at various points.
We installed it right in front of the hitch and it fits perfectly below the rails so we can still put our bed cover on when not using the truck.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
Veebyes
Posted: 04/11/17 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Got one that is half fuel, half storage. Wonderful. Can run 600 towing miles on mostly flat ground between fill ups. Separate control valves for engine feed & return.
2007 Alpenlite 34RLR
