Open Roads Forum
Print  |  Close
Topic: Question on one wire on Dometic RM2652 frig
Posted By: dpgllg on 04/13/17 03:35pm
I replaced the cooling unit on my frig and due to illness did not get the electrical connections completed last fall / winter
I had taken photos and labeled things but somehow I lost the images. I have most of the connections complete but there is just one wire that I can't find where it connects. If anyone can look at the attached photo and tell me where the small blue wire from the wire plug in the upper left of the control board goes I would greatly appreciate it.
Thanks in advance for your help
Dave
[image]Click For Full-Size Image.
* This post was edited 04/13/17 04:57pm by dpgllg *
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
Posted By: donn0128 on 04/13/17 03:38pm
You asked the exact same question back on 3/28. Didnt you get the answer then?
Posted By: enblethen on 04/13/17 03:51pm
Maybe this sheet from Dinosaur will help.Dinosaur
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Posted By: dpgllg on 04/13/17 04:45pm
No I did not or I wouldn't be asking plus I asked about all connections not just this specific wire.
What I got on 3/28 was about as helpful as your response today. I got a link to about 100 different wiring diagrams not that this wire connects here. I asked the moderator to close that thread but instead they just deleted most of the comments.
I am asking a very specific question about just one wire now. If you don't have the answer or unable to help then just don't answer. I resent the fact that I have to justify my question to you. Have you not needed a little help at some point in your life? If not then you are one very fortunate person
Posted By: dpgllg on 04/13/17 04:50pm
Thank you for your response but the wire in question comes from the plug in the upper left corner and the document only covers the wires across the bottom. This document will help me verify that I do have those connections correct.
Thanks again
Dave
Posted By: enblethen on 04/13/17 05:22pm
The top multi-conductor connector and cable comes from the inside control eyebrow.
The lower one goes to the thermistor located inside the refer mounted to the fins.
Posted By: Chris Bryant on 04/13/17 05:24pm
I don't recognize that configuration- but usually the blue wire is a test lead with heat shrink covering the end, and connects to nothing. It normally comes from the 4 wire plug though, the 6 wire all goes to the top board.
-- Chris Bryant
Posted By: dougrainer on 04/13/17 05:30pm
That wire is indeed a NON used wire. It is NOT connected to anything. Doug
Posted By: Toddupton on 04/13/17 05:32pm
Normally an eyelet like that is a fridge frame ground. Nothing else it would go to that I could imagine other than maybe a test point.
Posted By: DiskDoctr on 04/13/17 09:07pm
Thanks for asking this question!
I pulled the fridge today to replace the cooling unit and took pics of the connections. I also wondered about the blue wire [emoticon]
Did you get all the other wiring questions answered? I took pics if you need them.
Posted By: dpgllg on 04/14/17 06:05am
OP Here,
Thanks to all who responded. I appreciate your help in this matter!
Thanks again
Dave
Posted By: Chris Bryant on 04/14/17 06:10am
Here's the relevant wiring diagram- note the blue wire labeled "T"-
Print  |  Close
