RV.Net Open Roads Forum: What is the dumbest things about your fifth wheel?
 > What is the dumbest things about your fifth wheel?
Page of 9
Goostoff
Wisconsin
Posted: 02/06/22 09:30am Link  |  Quote  |  Print  |  Notify Moderator
dedmiston wrote:
2) Fresh water drain lines hang below the bottom of the tanks, so if you overfill by even just a dribble, 30+ gallons will siphon off and spill down the street.
Sorry to dig up an old thread but I came across this and had to share my DIY remedy. I got tired of pumping in 66 gallons of water only to have 30 of them siphon out on the pad and soak everything with water for half the weekend.
I went to Menards and grabbed some quick connect PEX fittings. I got a 90 degree elbow, a valve, and a 4 foot section of PEX. I trimmed the vent a little shorter, put the elbow on, added the tube to get it over to the side of the trailer and installed the valve. Now as soon as it is full and the water starts to run out I turn off the water and go close the vent valve. After the water has been ran a couple times or flushing the toilet a couple times I will just go back out and open the valve so it can vent
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Veebyes
Posted: 02/06/22 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Switch placement & which lights are on which circuits.
Also, why do RVs use fuses instead of 12V circuit breaker panels like boats do? Guess I know that answer. Breakers cost more.
2007 Alpenlite 34RLR
philh
Belleville MI
Posted: 02/06/22 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
NW 27-5L.
Wasteful very shallow cabinet under entertainment unit. I had the dealer pull the door off and put in a fireplace.
Area above water pump is completely closed off and wasted space. I've turned it into a 2 shelf cabinet for shoes.
Biggest issue, the whole pass through has not been well thought out as they carried sewer pipes through what could be a much larger area, but no, they completely blocked that area off.
With slides in, access to pantry is blocked and so is the bedroom clothes closet. Wife did a most awesome job turning the clothes closet into cubes and shelves.
valhalla360
No paticular place.
Posted: 02/06/22 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Veebyes wrote:
Never understood the obsession with accessibility with the slides in. I can get to the potty. I can get to one side of my 4 door fridge. When I stop for the night, no matter where, the slides are coming out. Never been a problem.
While we don't usually do long days, it's nice to be able to just pop into the fridge...grab and go.
But more an issue if you have something like the slide motor fail. Now getting access to the kitchen/bathroom/bed is really handy.
Also, one time we got caught in a helacious wind storm. We pulled the slide in and the rocking dropped dramatically. Because we had access, it wasn't a big issue.
On other notes:
- I agree, had dump handles under the slide and it was a pain to crawl under to use them.
- Rear kitchen doesn't mean you can't have access. We've had two rear kitchen rigs with good access while closed.
Another issue: Remote waste tank valves. Had one start leaking and the only way to get at it was major surgery to remove the underbelly covering. At least if you are going to do it, include an access panel...but much simpler to just put it right at the end of the pipe.
* This post was edited 02/06/22 07:10pm by valhalla360 *
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Posted: 02/06/22 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
dedmiston wrote:
1) No fresh water drain valve.
Actually on our current unit, it has a 1.5" drain valve (looks like a gray tank valve...but food safe, I assume)
OK option, but since it's usually a once a year thing to winterize, not a huge burden to unscrew the plugs we had on our prior units.
momentum rv
Central Cal.
Posted: 02/07/22 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Bathroom doors that open out into the hallway. Always in the way, and when closed you never know if someone is in there or not, always have to knock before opening. Pocket door is the ticket!
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
laknox
Arizona
Posted: 02/07/22 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Lights with no wall switches. How is a vertically challenged person, like a 4 y.o., supposed to be able to turn on a light if she needs to go potty in the middle of the night?
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
Cummins12V98
on the road
Posted: 02/07/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
And then you will be starting a thread about how the pocket door fell of it's tracks.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 02/07/22 10:19am Link  |  Quote  |  Print  |  Notify Moderator
We were at a friends Hitch Hiker and wife asked to use the restroom. She goes inside and hits the first switch she sees and the big living-room slide starts to come in and the big black cat literally flew across the RV.
Scared the SHITE out of all of us.
momentum rv
Central Cal.
Posted: 02/07/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, I've seen plenty of those threads but 7+ years and no issues with mine! (and if I did, I'd just fix it!)
Page of 9
