RV.Net Open Roads Forum: Dinghy Towing: 2013 Ford CMax death wobble
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > 2013 Ford CMax death wobble
TripleE
Ohio
Posted: 06/04/17 11:45am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2013 CMax and only recently started towing it. A couple of times when making right hand turns it has started wobbling. We have to pull over and come to a stop to get it to stop. Then it is fine. We do have a 4 inch drop tow bar. BlueOx is the setup. Anyone else have this problem?
Bill & Treasa
Our Blog
USMC Retired MGySGT
2005 Winnebago Vectra 40AD
400 Cummins, Freightliner chassis
2004 Suzuki Grand Vitara 4X4
sdianel -acct closed
Tampa, FL
Posted: 06/04/17 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
search death wobble in the search box above and you will find lots on the subject. Has to do with electronic steering. Affects Equinox, Jeep, many other vehicles. We just bought an Equinox and haven't towed it yet but are monitoring this topic.
TripleE
Ohio
Posted: 06/04/17 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of the death wobble before but had not heard of it in the CMax. My repair guys at Ford have never heard of it either. Asking for CMax owners to see if anyone else has the problem.
sch911
Rochester Hills, MI
Posted: 06/04/17 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
This happens to many new cars that have Electric Power Steering and are towed 4 down.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
afrescopXx
San Antonio
Posted: 06/05/17 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Had it happen once in the four years we towed our former 2013 C-Max. Coming out of a parking lot and making a right hand turn. As I said only that one time. Stopping and restarting plus a change of undershorts worked.
TripleE
Ohio
Posted: 06/06/17 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks sfrescop. It makes me feel a little better that someone else has had it happen. My Ford guys had not heard of it. We will take right hand turns a little slower and straighten out more before hitting the gas. I had an alignment done so will see if that helps.
Dluihn
California
Posted: 09/20/20 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2005 Monaco and tow a 2017 cmax. Have experienced death wobble on both left and right turns. Looking for fix.
lryrob9301
Mid-Atlantic
Posted: 09/20/20 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
The easy "fix" is to take a long bungee cord and loop it through the bottom of the steering wheel a couple of times and hook both ends under the driver's seat bottom frame. This will keep a centering force on the steering and dampen the wobble.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
Fifty4F100
Bartlett
Posted: 01/13/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
This might produce more dragging and tire wear on the front. I do see where it would be much easier on the undershorts!
Glenn in TN
2008 Ford F150 King Ranch
2012 Allegro Breeze BR32
2017 Mini Cooper (future toad)
purplekeenah
greensburg, pa
Posted: 01/14/21 05:35am Link  |  Quote  |  Print  |  Notify Moderator
As lryrob9301 mentioned, the bungee cord works well to eliminate the wobble. I've used the flat cloth(green & black) covered bungee with the plastic hooks that Walmart carries. My 2013 Equinox has a 4 cylinder that has electric steering, the 6 cylinder Equinox has hydraulic steering that does not have the death wobble issues. I started using the bungee after two years of towing the Equinox without any wobble, I think whatever wear occurs in the steering system over those years resulted in less resistance to movement. I make 5 wraps around the bottom of the steering wheel and hook the two ends under the front edge of the seat on each side of the Brake Buddy. It may have been 4 wraps around the steering wheel when the bungee was new, but it should not be stretched too tight, just a little snug.
I have not seen any issues with the tires wearing abnormally.
2015 Newmar Dutchstar 4369
2013 Chevy Equinox
