RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 484
fulltimin
Home is where we Park It.
Posted: 08/22/18 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
STBRetired wrote:
So I would gather that flat aluminum sheeting, like you would see on a cargo trailer would be out due to the poor appearance of all the seams. You can get rolls of aluminum in various alloys from metal supply houses. I would think .05" would be thick enough and you can get widths of 8' pretty easily. How to fasten it would be a challenge. You don't want to put a bunch of screws through it, so I guess you glue it on like filon. Not sure if it will telegraph the seams where your plywood sheets meet.
Do give some consideration to penetration protection. You would not want a wayward tree branch to open up the side if youe MH like a can opener. Saw that happen to a friend's stacker trailer. Fab'd up a 6' giant can opener to give them at the race banquet that year.
Those roofing panels that George posted do seem to have some potential.
I would assume that if the aluminum is thick enough, that would mostly eliminate the plywood seams. Gluing aluminum should be no different than gluing filon of fiberglass. Probably a pain, but do-able.
I like the giant can opener. Hope he had a good sense of humor. Lol.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 08/22/18 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
STBRetired wrote:
fulltimin wrote:
Ideally would be to stop the rolling and forming just before the window and door openings. That would allow for a flat surface for the window and door openings.
Then again, the original fiberglass was the same. Formed from front to back, and the factory just put a bunch of caulking between the window frame and the fiberglass. Of course, they leaked, so, there ya go. Lol.
J channel works pretty well on houses, I suppose you could caulk the dickens out of it to prevent leakage.
Yea, I am not a really big fan of caulk. I would rather build it where it would not leak water, even if there was no caulk. I know, easier said than done. Lol.
Bruce Brown
Northern NY
Posted: 08/23/18 04:42am Link  |  Quote  |  Print  |  Notify Moderator
The windows have a butyl putty tape in them, not just caulk. Double it up if needed. Make sure it's fresh when installed and it fills in nicely.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
STBRetired
I-80 and I-55
Posted: 08/23/18 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Have you considered using something like BlueSkin behind the siding? It would work well behind any siding that required mechanical fasteners instead of glue. They also make a butyl flashing tape in various widths.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
fulltimin
Posted: 08/23/18 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I've never heard of that. I'll do some reading on their website, to get to know it. Thanks.
wildmanbaker
Kennewick, Washington
Posted: 08/23/18 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Well, you asked for it, and your got it! I'm surprised that no one suggested flatting aluminum cans and tabbing them on the side.
Wildmanbaker
fulltimin
Posted: 08/23/18 08:31am Link  |  Quote  |  Print  |  Notify Moderator
What a cheap way to make shingles. I love it! Lol. Should I keep the logo side in, or out?
wildmanbaker
Posted: 08/23/18 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Out, of course.
fulltimin
Posted: 08/23/18 11:30am Link  |  Quote  |  Print  |  Notify Moderator
So, it could end up looking like this.......
or this.................
Just plenty of staples necessary!
Bill1374
northern New York
Posted: 08/23/18 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I'm kind of partial to a smooth fiberglass side, maybe in a soft white with a painted stripe or stripes down the side to break up the profile. Does not need to be a brite color nor very wide either.
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
Page of 484
