RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 542
fulltimin
Home is where we Park It.
Posted: 10/18/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
This is the meat of the lock system. The red arrow points to the little button on the inside that locks the door, or unlocks the door, depending on whether it is pushed in or pulled out, with no key needed.
The green arrows points to a pair of springs, (yea, this has 1 spring missing). That pushes the latch shut.
The blue arrow points to the piece of steel that slides the latch either in or out, which is the black arrow.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 10/18/19 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a close up of the locking mechanism. This is the pin that slides in or out, and here's how it locks.
The red arrow points to a larger diameter piece of steel, while the green arrow points to the smaller diameter piece. You can see the larger hole around the pin here. When the larger diameter drops down, you can no longer move the slide back and forth, so it's locked.
Actually, it's fairly simple, in the way it works.
fulltimin
Posted: 10/18/19 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the inside of the deadbolt. Nothing special here, just a standard deadbolt. Again, it's held together by 2 screws. This shows the bolt extended.
This one has the bolt retracted. The arrow points to the little round (doohicky), yea, that's a term, that rotates which will extend or retract the bolt.
fulltimin
Posted: 10/18/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
As you saw earlier, the door is mostly insulated, although it needs a little spray foam around the edges of the green foam board to finish sealing the inside of the door.
As far as security goes, I could do the same thing Fleetwood did, and use an aluminum frame and door, which is screwed from the outside into the frame of the coach.
If 2 people with with 1/4" sockets and each with a drill, or impact driver, in less than 2 minutes, can remove all the screws and the whole door just lifts off. How's that for security?
Also, if you look at the lock on your door, the type of lock I showed here, it will have a letter on it. I know they go from at least A to E, but I don't know if they go further.
Any dealer will have a master key that matches A thru E and will be able to open that lock with his master. More security.
They do not, however, have a master key for the deadbolt.
One more thing. There are hundreds of thousands of rv's on the road that have the same keyed locks on all of their outside storage compartment doors. The key will say CH751. If your key says that, you can probably open many of the cargo doors in the campground that you are staying in.
There are some cargo doors that have different key combinations, but there are a bunch of them out there with that combination.
Still feeling safe?
Bill.Satellite
Full-timer
Posted: 10/19/19 05:14am Link  |  Quote  |  Print  |  Notify Moderator
PastorCharlie wrote:
He mentioned that the hinges will be on the left side of the door in his post above my previous one therefore it is a swing door and not sliding.
If you are responding to my post, I never suggested he was going to use a sliding door...LOL....
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
PastorCharlie
NC
Posted: 10/19/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
I was responding to:
He seems to understand the minutiae of construction. I suspect he is not going to have a door that swings open and closed but does not have a way of properly securing it.
If it does not swing it slides.
fulltimin
Posted: 10/19/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Never ocurred to me until now. How about a gull wing? Lol.
STBRetired
I-80 and I-55
Posted: 10/19/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmmmm. Door opens up and provides its own awning. Gonna be hard to fabricate a hinge for that curved top.
BTW, whatever happened to the dutch door idea? Had one of those on the house where I grew up and it was pretty neat.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
fulltimin
Posted: 10/19/19 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing happened to the Dutch door. I am looking at my dimensions. The top portion of the door that I would cut off for the dutch portion of the door is about 25-26 inches high, and about the same width.
Due to the curve, I have about maybe 12-14 inches for a straight hinge. With a sturdy hinge, that should be do-able.
The other option, is to put a piece of glass that opens, in the upper part of the door, but the glass would be about 3 inches more narrow due to the current outer frame of the door.
This will be adjustable on the fly, so to speak. Lol.
Either way, I had to build a top piece to fit the door frame, whether I built it all in one piece, and cut the top off, or build the 2 sections of the door, separately.
I chose to do the door all in one, ad then I can cut it later, and still have a great fit above.
fulltimin
Posted: 10/19/19 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Son took us to the races tonight, to a track we have not been to in years. We left early to get decent seats, so I had no chance to do anything today. [emoticon]
But hey, we did have a great time! [emoticon]
Page of 542
