RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 592
fulltimin
Home is where we Park It.
Posted: 11/05/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Flipping the latch open, reveals an adjustment screw that will make sure the base is held tightly when closed.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 11/05/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
With the latch flipped open, you can see the screw which allows for minute adjustments of the base, both up or down.
Pushing down on the left side releases the screw and then the entire base can be slid up or down easily for a rough adjustment, and then finish off with the little screw mechanism for final depth.
fulltimin
Posted: 11/05/19 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
They even give you a wrench to change the router bit, and the other end is for adjusting the little screw to make sure the base is tightly fastened when the little flap is pushed shut.
When properly adjusted, the base fits tightly and will not move in any direction.
Like I said, I wish I had bought this sooner.
zigzagrv
Nazareth, PA
Posted: 11/06/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I have and use the original blue Ryobi router, which I believe was made to compete with the corded Roto-Zip, which I also have, and performs well in that role. So it was not meant to be a 'precision' router, which your new one appears to be. Very nice!
Early on I recognized the base was a bit anemic and made a 3" base from clear plastic, which attaches to the round base with 3 clamps. The main criticism I have of the old one is the lack of precision in adjusting the depth of cut, which your new one does very well.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
PastorCharlie
NC
Posted: 11/06/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
fulltimin wrote:
How do you like my door hinges? (Sort of).
The door told me it was cold, so I put another coat on it. Lol.
I figured, why not. One last coat of clear Por 15 for the outside.
If you plan to "dutchize" your door you will need 4 hinges.
fulltimin
Posted: 11/06/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
You betcha! Lol. Not going to cut that in half yet, but that is the plan. As of this fall, I am just interested in getting this buttoned up with no air leaks. Installing the door, will accomplish that for now.
fulltimin
Posted: 11/06/19 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Finally managed to get the door mounted today. No, I didn't use any special screws yet. First step in the right direction. No, I don't have a door latch yet to secure the left side.
fulltimin
Posted: 11/06/19 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
I finally got to use my new, little, cordless Ryobi router today. I must say, as I said last night. I wish I had bought that sooner. Oh well, at least I have it now.
I had to trim some excess 1/4" plywood so I would install the door today. It did a very nice job, and only weighs a couple of pounds, with the battery installed.
It is very easy to handle, and with the extra size base, much more stable than the little old blue one I had.
Who knows, maybe I'll add a slightly larger base plate. What little bit I did get to use it today, I was very happy with it. It will only take 1/4" bits, which is just fine.
It does not have near the power my Porter Cable does, but for a lot of jobs, this will do just fine. YeeHaw!!!
joerg68
St. Ingbert, Germany
Posted: 11/07/19 02:07am Link  |  Quote  |  Print  |  Notify Moderator
Getting there ;-)
I just noticed the headlights on your PT are pretty badly weathered. With all the tools at hand, why don't you polish them clear again? It will make a difference in the dark & wet months ahead.
https://www.google.com/search?hl=en&q=polish%20headlight%20lenses
STBRetired
I-80 and I-55
Posted: 11/07/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Quick question. Are you planning on making a screen for that door? Or are you going to use one of those magnetic ones?
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Page of 592
