RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 732
BigRabbitMan
Cottage Grove, OR
Posted: 06/23/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
As to the stove, that is a drop in that doesn’t need side shielding. Because the actual burners generate heat at or above the counter no side shielding is needed.
BigRabbitMan
Gas to Diesel Conversion project
76 FMC #1046, Gas Pusher became a Diesel Pusher
Discussion thread on this site
"You're never too old to learn something stupid."
fulltimin
Home is where we Park It.
Posted: 06/23/20 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
The black pieces that the pots sit on are above the white porcelain. We usually don't cook anything on high heat, so it should not be a problem. However, raising the entire drop in cook top by about 1/2" or so, would give more space between the pot and the black walnut, especially if we are using a large pot that overhangs the stove.
I'll have another look at it just to make sure I am comfortable with it.
Thanks.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
PastorCharlie
NC
Posted: 06/24/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I would think there would be more concern with what the black walnut is treated with than the walnut itself. Some finishes will off gas and are very flammable.
fulltimin
Posted: 06/24/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
I would think it would be a little tough to light up a counter top just from off gassing.
Then again, I suppose stranger things have happened. I've used a lot of Lacquer over the years, and fortunately never had a problem, and never want to.
Some of the inside will get Lacquer, but it probably won't be all at once.
fulltimin
Posted: 06/25/20 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Here's another shot of some black walnut that has 2 different finishes on it. This just has more coats than it did last time I posted it.
The top half has been coated with Lacquer, and the lower portion has Por 15, Clear, on it.
The bottom part was darker to start with, and you can see that on the upper portion towards the right. This is actually the same board, with a section in the center about 2" with no coating.
fulltimin
Posted: 06/25/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Q and A time, folks.
The wife threw a monkey wrench into my plans today. She suggested possibly, putting both the sink and the stove top on the same side. This would be on the drivers side, with the sink on the left, closest to the shower wall, to help shorten the plumbing runs.
That would allow the other side completely clear, which would amount to just a touch over 6 feet of free counter space, instead of 42 inches free on each side.
Give me some pro's and con's of doing it either way. Some one probably has thought of something we haven't.
Sink indicated on the left by a piece of plywood.
What do you think?
nohurry
Orting, Wa
Posted: 06/25/20 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Well, when I cook I like to have room next to the stove for ingredients, utensils etc. and I would think you would want room next to the sink for dish drain rack etc.
I don’t know if this applies to you and your wife, but what if you were cooking something and she was using the sink at the same time? Would you be bumping into each other with either setup?
No right or wrong answer, just what works for you two, but when in doubt, keep SWMBO happy. [emoticon]
Carl
2007 National RV, Sea Breeze
nohurry
Orting, Wa
Posted: 06/25/20 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just thought of this as well; how will cutting two holes, and having the weight of a sink full of water, and the stove with pans etc. affect the counter? Might have to do a little more support underneath?
Are there going to be cabinets underneath?
Bill.Satellite
Full-timer
Posted: 06/26/20 05:54am Link  |  Quote  |  Print  |  Notify Moderator
That's what I mentioned in an earlier post. That's how our RV is setup but, of course, there is a back splash behind and not cabinets or shelves. I can't imagine how your current setup would work. We also have a longer counter to work with, a narrow 2 burner gas cooktop and no counter on the other side providing better work space. On the opposite side we have a 2 seat bar setup against the wall for dining (big window with a nice view) and the fridge. Small work triangle and plenty of space for prep. You don't need a dish rack for drying. Clean as you go and then the after dinner dishes for 2 people is easy enough to wash and dry right out of the sink or set on a dish towel beside the sink.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
STBRetired
I-80 and I-55
Posted: 06/26/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
In the S&B, the sink and the cooktop are opposite each other. In the MH, the sink and stove are on opposite ends of the same counter. Both configurations work just fine. I would move the sink about 6" or so closer to the wall. You don't really need the space between the sink and the wall and the added room between the sink and cooktop would be more useful.
BTW, where are you going to put the trash bin? We have found that having the trash bin directly below the prep area is very convenient. A lot less messy to just scrape the scraps into the trash than to pick them up and carry them to another location.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Page of 732
