RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 693
fulltimin
Home is where we Park It.
Posted: 10/17/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
PastorCharlie wrote:
Did you feather sand the outer edges of the last center row of plywood to prevent a wear edge of the TPO?
That would fall under the category of "couple of minor things to touch up before gluing the TPO down".
I suppose it would be easier and take less time if I just added a strip of ChemLink M1 along the edges and smoothed them out a little.
Depends on how long it looks like it will take, and how I do it. Guess I'll have to have a little thought on the process.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 10/17/20 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Not the warmest place in the US for that kind of work, Just my thought's, best get it finished soon. everything lookin good.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
fulltimin
Posted: 10/19/20 06:16am Link  |  Quote  |  Print  |  Notify Moderator
We have our moments. When it's 95 degrees out, and the humidity is higher than the temperature, the heat index is 110 - and yes, we've had a few of those days this summer, that's not fun either.
Thanks for the posts. [emoticon]
fulltimin
Posted: 10/19/20 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Had to fix an "oops" today. Plywood will generally bend in one direction, but not 2.
The back of this plywood bends slightly down towards the rear of the coach, as well as bending towards the side.
So, since the adhesive was hard, I cut this out in 2 pieces, as shown by the red lines.
You talk about being tough to remove the adhesive? Wow, such a scraping and cutting trying to get it all off was definitely difficult.
I hope I'll never have to remove any of that stuff (adhesive), again.
fulltimin
Posted: 10/19/20 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
After getting it all cleaned up, I applied new adhesive, and then held it down with my nylon straps. The plywood took the bend nicely.
Now it's just time to wait and let it cure over night.
About 30 seconds after I strapped this down, raindrops started falling on my head. Lol.
That was fine. I pulled the TPO back into place and strapped it down and called it a night.
fulltimin
Posted: 10/21/20 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Little side trip tonight. Here's a few pictures of a small "wall" partition that came out of a typical rv.
Front side with oak looking vinyl glued to 1/8" plywood.
fulltimin
Posted: 10/21/20 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
This is the back side of that piece. As you can see, the edges have pieces of wood that are about 3/4" x 3/4". The center cross pieces are about 3/4" x 1.5".
fulltimin
Posted: 10/21/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
This is what holds the top of the "wall" to the ceiling. Just a couple of screws only.
fulltimin
Posted: 10/21/20 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
This is one of the cross pieces that is 3/4" x 1.5". There are no staples, nails, screws, or adhesive holding the thin plywood to the cross piece. The plywood was staples around the outside edges only.
fulltimin
Posted: 10/21/20 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
The corners were stapled together with one staple at each one, and again, no adhesive.
Page of 693
