RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 778
fulltimin
Home is where we Park It.
Posted: 04/07/21 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Next, I check to see if there is any play between the fence and a tooth on the saw blade. If the work moves, I know I will not have the same width cut as I have on the original.
Here, after pushing the work towards the blade, there is a slight gap between the wood and the fence, so I know it needs adjustment.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 04/07/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have the left side of the plywood against a tooth on the blade, not just the blade itself, as the tooth is wider than the blade.
Making sure there is no play between the blade tooth, and fence, I can cut the next set, knowing they will be the same size.
fulltimin
Posted: 04/09/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
While I am working on the drawers, I have a question.
I've been considering lighting inside, and would like to use all LED's.
We like the 6K lights, which are a bright light - more similar to daylight than the soft white lights, which are more commonly used.
I have 2 different sets of overhead lights which I can use LED's in. One set uses the standard 1141 type bulb.
The other set uses the T10 wedge type.
I would also like to use some LED string lights which are also 12 volt dc.
Any recommendations?
joerg68
St. Ingbert, Germany
Posted: 04/10/21 04:03am Link  |  Quote  |  Print  |  Notify Moderator
The only recommendation I have: You will not need very bright light in the drawers.
Try some of the lights in your home with a 12 V source.
With all the wires needed for the drawers, there is a risk of something getting caught or tangled up.
Do not forget proper fuses. You don't want an electric short to burn up the wiring (and start a fire...).
fulltimin
Posted: 04/10/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the post.
I did a poor job of writing that question. My fault.
I am not planning on putting lights in the drawers. I was actually talking about lighting on the ceiling.
There, that should be a little more clear.
Lt46
Central Florida
Posted: 04/10/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
For what it's worth, I pulled my 1141's out of my ceiling lights and replaced with LED.....not very happy and will probably go back to 1141's. LED's are bright at the fixture but the brightness diminishes not too far from the fixture. For example, when the ceiling light is "on" and I'm at the sink washing dishes, the sink is dark because my body blocks the light and the brightness does not project as far as I like. If that makes any sense.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
sundancer268
Charlevoix
Posted: 04/10/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the T-10 type bulbs with this flat panel https://m4products.com/alplate-24-5630-nw-natural-white-double-aluminum-plate/ I am very happy with these plates and they come with various adapters to fit the many light sockets. I applied them to my fixtures using RTV Silicone caulk instead of relying on the double sided tape.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
fulltimin
Posted: 04/10/21 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply.
Makes perfect sense. Would it make much difference if the light was more directly over the sink?
fulltimin
Posted: 04/10/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link. I just ordered one to compare with what I already have. I see these have 2 pigtails to work with either type of socket.
Supposed to be here next week - maybe. Lol.
I'll give a comparison.
fulltimin
Posted: 04/10/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have 6 more drawers to assemble for this section beneath the counter.
Tonight, I cut the grooves in all of the drawer pieces for the drawer bottoms, which are - (you guessed it - not quite 1/4" in thickness)!
That required 2 passes with a router bit that was less than 1/4" in order to get the required width of the groove.
1/4" bit would make the plywood fit looser than I would like.
So, I now have 12 drawer sides, with the grooves.
Page of 778
