RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 773
fulltimin
Home is where we Park It.
Posted: 04/22/21 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Getting closer to the install of the first set of drawers. I want to add some furniture wax to the slides and see how they slide, before I put the assembly in place.
I have no reason to think they won't work, but I want to make sure before I screw the assembly in place.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 04/22/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 questions for anyone who knows more about this than I do.
1. If I divert the urine from the toilet to the gray tank, is that still considered ... gray tank? Black tank, would only have to be black only, with water, of course, correct?
2. Does anyone know of a 120 volt ac inline water heater, that is able to control the temperature of the water by adjusting the voltage to attain the correct output temperature? I don't want to just use a mixer to add cold water to get the correct temp.
Thanks.
sundancer268
Charlevoix
Posted: 04/23/21 05:13am Link  |  Quote  |  Print  |  Notify Moderator
I have always filled my Gray tank faster than the black and my coach dumps the bathroom sink into the black. Only the kitchen and shower dump to the gray and it still fills up about twice as fast.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
BigRabbitMan
Cottage Grove, OR
Posted: 04/23/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
On my coach, the toilet and kitchen sink go into the black and the bathroom sink and shower go into the grey. Based on our use patter they fill at a comparable rate.
BigRabbitMan
Gas to Diesel Conversion project
76 FMC #1046, Gas Pusher became a Diesel Pusher
Discussion thread on this site
"You're never too old to learn something stupid."
LouLawrence
Traveling the US!
Posted: 04/23/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
You Cray Cray!
fulltimin
Posted: 04/23/21 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the posts.
fulltimin
Posted: 04/23/21 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
You Cray Cray!
Yea, pretty much.
My thought process was how it would work using an incinerating toilet, but hadn't researched it at all.
Turns out, that the incinerating toilet will burn both solids and liquids, and save a bunch of water.
Just looking at my options.
fulltimin
Posted: 04/23/21 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Anybody with info on the inline electric water heater?
joerg68
St. Ingbert, Germany
Posted: 04/24/21 03:50am Link  |  Quote  |  Print  |  Notify Moderator
Have you googled something like "constant temperature tankless water heater"?
The ones I could come with were all 240V - which makes sense, as heating water quickly takes a lot of energy.
If it is not a tankless system, I don't know how you could go without mixing in cold water to achieve the desired temperature.
fulltimin
Posted: 04/24/21 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have not. I thought maybe someone on here was familiar with tankless electric water heaters, and could save me some research time.
Thanks for the info.
Page of 773
