RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 772
fulltimin
Home is where we Park It.
Posted: 06/02/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Why did I do this?
Because I could? - Actually, no.
I wanted to clean up some of the "stuff" that I had on the counters, but I am not ready to put permanent drawer pulls on the drawers yet.
I also wanted something that was easy to remove, and not damage the plywood, hence the removable strips.
After cleaning some of the "stuff" from the counter top, we end up looking like this.......
I have some things in the drawers, and off the counter, and it feels much more organized than it did. Wahoo!
When I get ready to finish off the drawer fronts, these blocks are easily removable, which is what I was looking for.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
Bruce Brown
Northern NY
Posted: 06/03/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
That looks nice.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
fulltimin
Posted: 06/03/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Bruce Brown wrote:
That looks nice.
Thank you. Can only get better, right? Lol.
fulltimin
Posted: 06/03/21 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I figured that it's only a matter of time until the question comes up, "how hard is it to pull those drawers open with weight in them"?
Well, I am glad you asked.
This first picture I screwed up. I didn't realize that I had zoomed in too far to get the entire weight that I was weighing.
It is a box of Kreg screws, that is not quite full.
Amounted to 23.69 lbs.
fulltimin
Posted: 06/03/21 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
With the screws in the drawer, towards the back of the drawer, I made sure the scale was set at zero.
fulltimin
Posted: 06/03/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Then I started pulling on the scale. The pulling weight did not change much during the length of the pull.
The drawer was about 5" from coming out, so it was "nearly" out as far as I wanted it to go.
3" is about the max that I am comfortable with, using this type of slide. There are other types of full extension wooden drawer slides, but for this design - no.
fulltimin
Posted: 06/03/21 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't measured it yet, but our refrigerator in our house may require more effort to open than this drawer does.
On the other hand, how often do we have 25 lbs or so of weight in our drawers.
Most of the time, it will be far less, which will require less pull strength.
I'll have to check out a couple of other drawers.
navegator
San Diego CA.
Posted: 06/05/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
How do you plan on keeping the drawers closed when traveling?
We had the pantry door open on a very tight left uphill turn and the contents go flying out, after that I installed the drywall corner L strips and drilled holes to accept bungee cords, they are on for travelling and one side off for camping, all the drawers on ower unit need to lift up to open.
navegator
fulltimin
Posted: 06/05/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
navegator
That's one of the things I haven't settled on a solution yet. I am still looking at options.
Bungees would be a cheap and easy option, but I haven't finalized anything yet.
Thanks for the post.
LouLawrence
Traveling the US!
Posted: 06/06/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
These
Page of 772
