RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 800
fulltimin
Home is where we Park It.
Posted: 06/19/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you look at the area above the door, turning a flat wall space into something that looks a little more "sophisticated" than just a flat wall only requires a little fairly inexpensive trim.
The drawer fronts should be as easy to upgrade the look as well.
Thanks for the ideas.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
Bruce Brown
Northern NY
Posted: 06/20/21 05:32am Link  |  Quote  |  Print  |  Notify Moderator
fulltimin wrote:
Bruce Brown wrote:
fulltimin wrote:
Quick survey .... Put the walnut on top, or rout the drawer front out, and mount it flush? Whatta ya think?
Is this even a question?
Let me rephrase...
Should I cobb it together or do it right?
I will admit, I'm surprised you even needed to ask.
Bruce, Bruce, Bruce... You need a little decaf. Lol. Joking, of course.
I'm on my second cup of real coffee so far this morning, so maybe?
But honestly, I think it'd look pretty amateur and tacky if you just stuck it on the surface and left it. Not to mention all the cr*p that would get caught on the ledge where it sticks out.
As unconventional as everything else you've done at least it appears to be quality work. Just tacking that on the front would not be considered quality IMO.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
zigzagrv
Nazareth, PA
Posted: 06/20/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I'm going to break from the pack here and suggest putting the black walnut on top and adding a piece to the center of the drawer where the pulls will be creating a sort of bas-relief look. Would give it a bit more character. Simply rounding the edge of the trim would eliminate the chance of catching something on it. JMHO
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
fulltimin
Posted: 06/20/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Bruce Brown wrote:
fulltimin wrote:
Let me rephrase...
Some days I amaze myself. I post something which looks fine at the time, and when reading it the next day, I think "what was I thinking"? Lol.
The picture I had of the trim on the front, with the edge sticking out, was not intended to be what it will look like when finished.
Let me try again. Hopefully, it will make more sense.
fulltimin
Posted: 06/20/21 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the post.
All I can say at this point, is, stay tuned.
fulltimin
Posted: 06/20/21 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a drawing of what a little bit of trim can do for a door. It's a flat door with just a little bit of trim.
fulltimin
Posted: 06/20/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a box with a flat front, with just a little bit of trim in the front, which adds to the overall appearance.
fulltimin
Posted: 06/20/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a set of drawers, with a little trim added to the front, around the edges, to make it look a little "classier".
This is more of what I was trying to get across, but didn't do a very good job of getting it accomplished.
After 4 years, you would think I could do a little better, wouldn't ya? Lol...
fulltimin
Posted: 06/22/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Wahoo! More work done.
In this pic, I cut some black walnut strips just a little over length, which is shown by the blue arrow, and then proceeded to glue them to the sides of the drawers to cover up the plywood plies.
As the red arrow shows, I had to cut some plywood pieces to be able to clamp the thin walnut to the drawer sides, until dry.
fulltimin
Posted: 06/22/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
These drawers are also waiting for the glue to dry. Once it does, which will be tomorrow, I can pull the clamps off and proceed to trim the walnut.
There we go. These are all of them, except for the one on the bench, which is in the first picture.
Good thing, because I am running out of clamps. Lol.
Page of 800
