RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 773
fulltimin
Home is where we Park It.
Posted: 07/25/21 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
nohurry wrote:
A man can never have enough clamps.
Yup, I think I may have to make a Harbor Freight run! Lol.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 07/27/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I finally finished my sink pattern for the sink sidewalls today. I suppose I should have done this right from the beginning, but I wanted to see how things would work with the small strips of wood.
Since it looks like it should work ok, I finished it today.
fulltimin
Posted: 07/27/21 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just in case you're wondering, the pattern is about 10" high. I used 2 x 3's - 4 of 'em high.
The inside of the finished sink should be about 15" x 22" and between 8 and 10 inches deep when finished, since it will be tapered.
Why so large? I want to be able to put a 12" pot/pan in there, and anything much smaller than that will not work.
LouLawrence
Traveling the US!
Posted: 07/28/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
This is one of those cringe worthy moments after showing the wood sink idea to the DW. I wonder how it will ride on those upcoming wooden tires.
navegator
San Diego CA.
Posted: 07/28/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend rounding the bottom corners also, square corners are hard to clean.
Look into the west system for doing the fiberglass and epoxy, I used it many times when installing navigation instruments on very expensive yachts.
navegator
fulltimin
Posted: 07/28/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
navegator
Should not be cringe worthy. This "box" is not the sink. This is only the "form" that I am making to glue the sides of the actual sink together. The "sides" of the sink will be glued around, but not to, this form.
These ...............
And these .......
Will be the actual sides of the sink. They should end up being about 1/4 inch thick, with Fiberglass/Epoxy on the inside to water proof things.
I guess I wasn't very clear about it, if you thought the 2x3 box was the actual sink.
Sorry. Hope that clears things up a bit. If not, stay tuned, it will soon become more clear.
fulltimin
Posted: 07/28/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
As I have said on this thread before - some days, you are the bug, and some days you are the windshield.
Today was a windshield day. ! Yay! [emoticon]
I wanted to make sure my jig for the sink glue-up was nice and flat, so I created a little secondary jig to flatten it with my portable router.
What I did was to screw a straight edge on both sides of the jig, and made sure they were parallel, like the above pic.
My router setup will be explained.
fulltimin
Posted: 07/28/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
My setup looks like this. I took a 2" wide board and attached my router to it.
fulltimin
Posted: 07/28/21 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
I took a couple of pieces of plywood and notched them out just a little bit - red arrows, and then secured the base of the router with a couple of screws - blue arrows.
fulltimin
Posted: 07/28/21 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Next was to run the router bit through the wood, so it would extend below the bottom of the board just a little bit.
Page of 773
