RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 825
fulltimin
Home is where we Park It.
Posted: 12/05/21 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I then, drilled additional holes in the side pieces for the Kreg screws.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 12/05/21 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
When I am assembling pieces like this, and need them to be flush on the ends, I typically like things up like this.
Then on the inside, I put a clamp up against the piece which has the screw in it, so as to not allow the screw to pull the side in, and cause an alignment problem.
fulltimin
Posted: 12/05/21 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
Time to test fit the box again, and at least it fits. It's a touch loose, but, it will be fine. Not that big of a deal, other than hurting my feelings.
Got no one to blame but myself.
cruising spud
Pennsylvania
Posted: 12/06/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
fulltimin,
As someone who checks out your posts several times a week, I have a question (now, I'm sure the answer is tucked somewhere is all of your posts, but I don't have the stamina to look through them). Once your inside build is done, do you still have the engine/under the hood stuff to do, or is that all done? Also, I just have to ask-are you just taking this one day at a time, or have you considered a possible end date to all of your work? I admire all the work that you have done.
LouLawrence
Traveling the US!
Posted: 12/06/21 11:39am Link  |  Quote  |  Print  |  Notify Moderator
No, engine work has yet to be done. No, there is no end date.
PastorCharlie
NC
Posted: 12/06/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
When one enjoys their work why rush to have it all end?
LouLawrence
Traveling the US!
Posted: 12/06/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
The enjoyment should be in the use of the product. This is anything but! If you are actually a Pastor you must understand that his wife is a Saint!
donkeydew
OR
Posted: 12/06/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
is that going to be a one holer or two when in gets assembled ?
that is a mighty fine box
fulltimin
Posted: 12/06/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
cruising spud wrote:
fulltimin,
I don't have a hard end date. The sooner the better would suit me just fine.
It's a one day at a time project. Some days go better than others, as the last posts show. Lol.
Hope to try to get it running in 2022, since it didn't happen in 2021.
Thanks.
fulltimin
Correct.
Page of 825
