RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 422
fulltimin
Home is where we Park It.
Posted: 01/10/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Then I added cut at every 2" in between the 4" measurements, and then added 1" cuts towards the bottom, shown in the red circles.
We're getting closer.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 01/10/19 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Still too wide at the bottom. Time for more cuts.
I added cuts at the one inch mark, so that all the area inside the red arrows, are now cut at 1" intervals.
The area inside the yellow circle, is still cut at 2" intervals.
And we are still too wide.
Not only are we too wide, the shape doesn't suit me, either.
fulltimin
Posted: 01/10/19 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, lets just finish the rest of the piece with all 1" interval cuts, with the exception of the bottom 4 inches on each side, and see what we end up with.
Now we can bend this puppy even farther than it needs to be, as indicated by the yellow circles. That is where the new piece needs to be attached to.
fulltimin
Posted: 01/10/19 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Now I relaxed the strap just a little bit, and we have a nice fit at the bottom. The arch suits me just fine, and although the top is just a little higher than I want it. I have 4 inches on each side, that can be removed, before I start hitting the cut marks.
That would bring the top down by 4 inches, which should be nearly perfect. If I need to, I could cut a little more off the bottom, to drop the top of the door just a little bit.
All in all, I am satisfied with the shape, and now, all I need to do is weld the slots shut, do a little grinding, and we're good to go.
Is there a better way to do this? Probably. Making a template and taking it to a place that can bend steel, would have been easier, (maybe), but until I got done making the template, running it to have a piece bent, and then bringing it home. ? Well, I figure it's almost as quick, doing it this way.
Besides, what fun would that be? Lol. Hey, if I wanted everything to be easy, I'd have just bought another rv and eliminated all the work.
Then again, I would not have learned anything, either.
So, here's where we stand tonight, and welding to start tomorrow. (I hope)!
fulltimin
Posted: 01/11/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a pic from today, where I took the piece of steel that I had cut all the slits in, and a pair of clamps and clamped it into place.
The 2 red circles, show the very bottom which has about 4 inches that is uncut. The very top, (red arrow), shows this is a little higher than I would like.
So, before doing any tack welding, I cut about 2.5" off of the bottom.
fulltimin
Posted: 01/11/19 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
After cutting the bottom off, that lowered the top of the door frame, and is now about where I wanted it. You can see by the red arrow, that there is now room at the top between the top of the doorway and the top of the wall frame.
The bottom of the arch with the red circles, can be seen only about 1.5" to the first cut slit.
Good news! I didn't forget how to use the welder! Lol.
I tack welded the inside, also the front side, then turned it around and tack welded the back side. That was all done with the clamps in place.
fulltimin
Posted: 01/11/19 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
After all the tack welding, I pulled the clamps off, and as seen by the red circles, the welding only pulled the arch together just a tiny bit.
The left side is off by maybe 1/8", and the right side by about 1/16". Anytime steel gets welded, especially like this, the heat is going to pull the steel one way or the other.
It's something to be aware of. What I'll do next is to slightly pull the bottom apart and clamp it, and then finish the welding. After the welding, comes a little grinding to smooth things out, and then, weld the bottom in place.
Overall, the arch looks pretty uniform all the way around. I plan on getting that welded together and ground tomorrow.
By the way - snow forecast for tomorrow night into Sunday. Amount = a dusting to a plowable snow, whatever that is. Lol.
It'll be, whatever it'll be. Leave it alone long enough, and it will melt.
I was hoping to get this fully welded, and welded in place today, but it just didn't happen.
Goodnight folks! Bedtime.
STBRetired
I-80 and I-55
Posted: 01/12/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
The arch top door just an asthetic choice? Your original door was rectangular.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
fulltimin
Posted: 01/12/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Partially. I want to make a dutch door, so I can open the top half, while leaving the bottom closed.
Just like the rest of this build - something different.
STBRetired
I-80 and I-55
Posted: 01/12/19 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Perhaps a round window or a porthole? Going to stay with the standard rectangular windows for the rest of the MH? Maybe frameless? Was at the Gulf RV show yesterday and the frameless windows look slick. Bet they cut down on wind noise while underway as long as they seal properly.
Page of 422
