RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 420
mike brez
Unknown
Posted: 01/12/19 09:44am Link  |  Quote  |  Print  |  Notify Moderator
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
fulltimin
Home is where we Park It.
Posted: 01/12/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Well, since I don't have permission to use this one ......
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 01/12/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I do, however, have 2 thumbs up from the wife, to use something like this.....
Although, yes, I have to round the top of it to fit!
fulltimin
Posted: 01/12/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
No comments on the door? Really? I'm surprised. Lol. Hey, whatever.
First step for tonight was to tack weld the loop for the upper door frame to a piece of scrap steel.
fulltimin
Posted: 01/12/19 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Second step, is to take the other end, use a clamp, and pull the bottom apart just a little bit. I pulled it about 1/2" farther apart than what it should be when everything is welded. We'll see how much pull we get after welding all the slits together.
fulltimin
Posted: 01/12/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Then we weld all the slits and after it's done, hold it up to the frame where it needs to be welded to, and see how much it pulled together.
As you can see at the bottom on both sides, it pulled just a little too much. Close up pictures coming.
fulltimin
Looking at a close up on the left side, we can see that this side is pulled in about 1/2" more than what it should be.
fulltimin
Posted: 01/12/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
The right side shows the same deal. About 1/2" pulled inward.
As I said, welding heat will always pull towards the side where the heat is applied. The more welds on a given side, the more "pull" you'll get.
Next will be to straighten up the last few inches on each side, so it lines up correctly. I may put one slit on the outside a few inches up from the bottom, and that should straighten things out pretty well.
One slit and one weld on the outside on each side should do it, two at the most, and we'll be good to go. Yay!
femailyetti
South of Disney World
Posted: 01/13/19 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you should rent a shrinking and stretching machine. The guy a the body shop has one he does some twenty's and thirty's car repair with. O may be A English wheel. Eastwood makes a English wheel.
fulltimin
Posted: 01/13/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Since this is just a one off, I'll just deal with it. I am almost ready to weld this into place.
Page of 420
