RV.Net Open Roads Forum: Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > Anyone interested in 83 Pace Arrow Tear down and Rebuild?
Page of 499
fulltimin
Home is where we Park It.
Posted: 02/08/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
After I tried it with the insulation running sideways, I decided to try it with the insulation running long ways, which I could not get to work earlier.
What I did was to put the piece of insulation against the roof, without bending it. That would be what the red arrow is pointing to.
The blue arrow shows I added a second piece of insulation underneath the first one.
Below that, I took 2 pieces of plywood, (green circle), and held it in place, and then put a brace underneath that and slowly added pressure from side to side, until the top piece of insulation was fully seated.
You can see inside the yellow circle that the piece of insulation I put up there has one of the score lines on it, running the same direction as the one in the center. That means the short piece is running the long way instead of sideways.
Evidently, having that extra piece of insulation on the bottom, spreads out the force of the braces, enough, that it will bend and not snap.
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
fulltimin
Posted: 02/08/19 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a closer pic of the bottom of the piece of insulation that is against the ceiling. The green arrows show that the bottom side of the insulation has sort of wrinkled.
Compression will do all kinds of funny things.
fulltimin
Posted: 02/08/19 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
This is a close up of the opposite side and it too is wrinkled just a little bit.
You have to remember, this piece is running lengthwise, (which is the stiffer way), and not crosswise. Running the insulation sideways like I did on the rest of them, did not wrinkle the insulation like this.
You can also see that the top piece of insulation is not split, or cracked, in either photo.
fulltimin
Posted: 02/08/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Continuing this process, I filled in 5 of these "holes" on the passenger side. I will leave them sit for 2 days for the adhesive to cure.
This pic shows the back half of the coach.
fulltimin
Posted: 02/08/19 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
This pic is of the front half, with some overlap. That means half of the right side now has insulation installed. Hopefully, in a couple of days, I'll get to finish the other 5 slots.
That's where we stand at the moment. Yippee! Lol.
joerg68
St. Ingbert, Germany
Posted: 02/09/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Excellent! Looks like the insulation part is nearing its end.
And congratulations - at almost 4000 replies (3974 as I am writing this), today is the first time I saw your thread at the top of the "Popular" page! It may have been up there before, I am not actively watching ;-)
tarnold
georgia
Posted: 02/09/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Now that most of your ceiling is done, was there consideration for a company that does spray foam insulation for your job? Those ceiling ribs would make good runners for screeding to level off after it cured.
STBRetired
I-80 and I-55
Posted: 02/09/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Looking good! Glad to see that you found a way to use the pieces of insulation you had cut off.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
fulltimin
Posted: 02/09/19 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to be getting near the end of the insulation.
Thanks for the congrats. I don't check it all the time, but this thread is usually near the top of the (Popular) page. Has been for quite a while.
Should be hitting the 4000 shortly.
Glad to have you along for the ride, and again, Thank You. [emoticon]
fulltimin
Posted: 02/09/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I never really gave it much consideration. I know spray foam is very quick, especially if having the pro's do it. Would have been done probably in a day, or two at the most.
I wanted what I figured was the extra strength that I figured the foam board would provide.
I had read of a couple people who used spray foam, and over time due to vibration and slight movement in an rv, that the foam started to fail.
There may have been other conditions that also led to the failure, but I figured, the stronger the better, which is why I went with the foam board.
Using the Chemlink M-1 for adhesive creates a very strong bond. I have a couple of pieces of foam "glued" with Chemlink and I cannot break the bond between the 2. That's exactly what I was looking for.
Thanks.
Page of 499
